Any help or info. L83 swap in 98 pick up
I’m doing a l83 swap in my 98 Chevy truck. I would like to know what are the the best options for the oil pan and motor mounts. And what headers will fit aftermarket or lt1 exhaust manifolds
I used stock manifolds in a c10 swap.
Used stock oil pan, but I did have to box the cross member for clearance.
Used ICT billet swap mounting brackets.
U will also need a ICT billet bracket with a corvette power steering pump for power steering. I used a Speartech standalone harness that worked great.
I sent in my harness to current performance. And I got the dirty dingo mounts but I was also looking in to the ict ones. What did you do about the vacuum pump did it clear your Crossmember and do you think the Camaro Pan would work?
2015 L83 accessories help!
i have a 2015 l83 that I am swapping into my 86 K5 but am unsure what to do when it comes to the accessories (mainly vacuum line, power steering, ac)... Could I unbolt the 2015 accessories and bolt on some from like a gen 4 or 3? Or is there a better option? Don’t want to break the bank... thanks!
6l80e into 73 c10
I was wondering if anybody knew how much or if any fabrication is need to install 6l80e automatic trans to a 73 c10 square body?? I’ve been looking can’t find anything on this
