Generation V External Engine LT1 Bolt-Ons | Intakes | Exhaust | Ignition | Accessories
L83 LP fuel pump upgrade
Old Oct 20, 2018 | 05:41 AM
littlefield's Avatar
Default L83 LP fuel pump upgrade
Whippled 5.3 in a 2016 Silverado with supporting mods including LT4 injectors and HPFP. Stock LP. 572rwhp on E10. Next weekend I’m trying different alcohol levels maybe up to around E30 logging data at the track. Plan to increase until seeing LP fuel or a/f limitations.
Disclaimer-I’m easily frustrated by search functions and have only given it a half hearted attempt.
What’s the capacity of the stock pump? I read about a Caprice PPV pump, Thats the current model and is a good option, I reckon? Any idea on the capacity increase with that pump?
Old Dec 27, 2018 | 12:16 PM
Little different question, does anyone have information on mounting configuration for an LT4 lpfp? I’m wondering if I can graft one onto the long truck L83 mounting supports. If somebody had an old LT4 DI in tank pump I would be willing to buy it. Does not need to work.
Old Sep 11, 2019 | 05:33 AM
Tim Bridges's Avatar
Default Did you get anywhere
I currently have a 5.3 2015 yukon with a tsp stage 1 cam,long tube and a edelbrock supercharger. I only installed lt4 hpfp and was able to run e30. Would like to get it to e85 was wondering if you ever got anywhere with your lpfp.
Old Sep 11, 2019 | 10:19 AM
kinglt-1's Avatar
Have you considered a JMS voltage booster?
Old Sep 11, 2019 | 05:17 PM
I have not how is that going to effect the pumps life span. This is my daily so I want to make sure it is reliable and not gonna be replacing pumps every 12 months
Old Mar 16, 2024 | 01:30 PM
Lucho1970's Avatar
Did you have any issues with clearance using the LT4 el pump? I have a 2017 Sierra 5.3 with an edelbrock supercharger. I'm upgrading what I can to get more power. LT4 hpfp is one of my options. But was told it might not fit. Don't want to buy a pump and have it not fit without mods.
Thanks
