L83 swap - fuel pump control module
I have an issue about the fuel module harness wiring, everything is fine and connected to the ecm, pressure sensor is connected everything is good except there is no power in PIN8 in the connector which is the fuel supply voltage wire that I should connect it to the positive wire of the fuel pump.
So the car doesn’t start because the fuel pump is not working because there’s no power from the positive fuel pump wire from the module.
I checked the wire and the plug for cracks and it’s fine, I’m using new control module and sensor.
the ecm shows 2 codes
1- secondary fuel pump circuit is high - P0232
2- ISO/SAE reserved - P023F
It seems like the fuel pump have its own signal because when I turned my key on I found a signal in the positive fuel pump wire. Maybe because of the old relay system
Pump im using is aeromotive 340
please help
please help
