Mechanical cooling fan setup L84
I find the old school thermostatic clutch fan dead reliable and very simple, looks period correct and confuses "experts". Note to mention it is one less thing to go gunnybags!
I noted on my 2020 5.3 crate motor that the water pump had a threaded section - this intrigued me.
Measurements show it to be a M30-1.5 thread. Why? it served no purpose in installation and as far as I can see no use in rebuilding the pump. By dumb luck I noted in a youtube video that a Ford Ranger had the same thing. The water pump seemed suspiciously centered in the radiator shroud too... this is the pump: GM 12687631
no way the thread and pitch are the same...
Way. I ordered a HD blade section and clutch - it fit perfectly.
I will need to notch the fan blades a bit and shorten the air intake elbow but this is easily doable. Part applications is 1990- 2011 Ranger 4.0 w/ HD cooling:
Blade:
VDO / CONTINENTAL FA70332 {F3TZ8600B, F3TZ8600C, FO3112102} Info
w/ Heavy Duty Cooling
$19.29
DORMAN 620112 {Click Info Button for Alternate/OEM Part Numbers} Info
Automatic trans.; w/Super Duty Cooling
Clutch:
Severe Duty - Thermal
SKP SK36720 {6L2Z8A616BA, 6L5Z8A616BA} Info$33.89
GPD 2911246 Severe Duty Info
Severe Duty
$40.79
GMB 9252040 Thermal; Severe Duty Info
Counter Clockwise (Reverse) Rotation (Only 1 Remaining)
$41.79
HAYYDEN 2794 Thermal; Severe Duty Info
Reverse Rotation
$42.89
FOUR SEASONS 36720 Thermal; Severe Duty Info
Reverse Rotation
$45.79
FVP 9252040 Thermal; Severe Duty Info
Blade:
$19.29
Clutch:
Severe Duty
$40.79
$41.79
Reverse Rotation
$42.89
Reverse Rotation
$45.79
FWIW the Express vans still come with mechanical fans. Ecotec 4.3L and 6.6L gas vans both have mechanical fans.
I clipped the tips a bit to clear the fan after I mounted the radiator and shroud. I ginned up this little widget out of tin
so all the cuts would be the same. I used a pair of bull snips and finished it off with a file and sandpaper.
The 90 degree inlet was trimmed back a 1/2" also and mounted. Clears the fan now by 3/8"
