A comprehensive look at the direct-injected heart of the 2014 Corvette [GMHTP]
another tiny..small... significant detail about the LT1.. boring it out is going to be very difficult as the deck is all aluminum and the liners are cast into the block underneath that.
GM has a LT1 at the Sema show. They announced the engine last week and then hustled it out here to SEMA. I was surprised at how small the mechanical fuel pump was. Sits under the intake to muffle the noise.
really? the camshaft is not baby, actually its pretty big. Anyways, the factory cyl heads are not bad either, they flow pretty well, and do really well cnc ported. High boost levels are a product of more fuel, more air, more power (double). Yes with higher flowing heads and better cam, boost will go down, but it will like 5psi less.
"Cylinder head sealing has been improved through the use of an all aluminum deck surface (cast over liners) and the inclusion of M12 cylinder head bolts."
i think that will play havoc with some wilder setups given the EXTREMELY different expansion characteristics of both metals.
A buncha BS changes for emissions only. I'm not impressed in the least. I'll be sticking with Gen3/4 platform for performance needs as I suspect 99.9% of others will as well.
The Scammer Hammer
I agree with red. Between the DI, cam and fuel pump, the liners being cast into the block & over, and the rumors of the PCM being locked and direct-linked with GM computers being able to yank your warranty at the blink of an eye, I'm not that excited at all.
GenIII for me.
GenIII for me.
GenIII for me.
GenIII for me.
GenIII for me.
GenIII for me.
The Scammer Hammer
And you're right. I'm afraid to "pay to play" and mod my motor....
#35
Sweet engine, but what bothers me is the name. couldn't they have used a different letter sequence?? This is what- the third time "LT1" has been used. (yes, I know one of them had a dash in it)
BTW- here are a few pics of the engine at a media presentation I took Monday night before SEMA
#37
I am wondering why they are only showing 20 HP over the Ls3 after all the expense of development? The torque is nice but I would have expected 500 HP plus out of this motor. The new locked ECM is going to suck because even though DI is great for boost you won't be able to tune for it.
#39
I wish they would have driven that tiny high pressure fuel pump off the front of the crank or cam gear instead of all the way at the back.
#40
That's MISTER MODERATOR
The new heads have the locating dowels (spring pins) relocated and apparently use larger head bolts. I suppose if the bolt spacing and bore spacing is the same, you could make something work, but the chambers were designed for DI and higher compression. Not sure how well they are going to work if you use port injection or carb and I'm not sure how you would retrofit the DI on an earlier block.
Agreed. This does seem foolish as it must really load up the entire camshaft. They'd better carve them from 4340 bar stock.
