Generation V Internal Engine 2013-20xx LT1
Direct Injection = Carbon Buildup?
Old Dec 31, 2012 | 08:16 PM
Whistler's Avatar
Sawzall and Welder Mod
Evidently from the buildup of oil residue from the PCV system since there is no longer a fuel there to act as a constant solvent. I was completely unaware of this, having owned a335i in the past that ran awesome even as the mileage got high. I based my opinion completely anecdotally and stand corrected.
Old Dec 31, 2012 | 08:25 PM
redtan's Avatar
But wouldn't a simple properly setup catch-can solve this issue completely even on a direct injected engine?
My LS2 intake would be dripping with oil before I installed the catch-can, although the port injection did keep the intake valves clean. In the 20k miles since I've installed the catch-can, I haven't seen a single drop of oil in the intake manifold...it's bone dry.
Old Jan 1, 2013 | 03:09 AM
obZidian's Avatar
I believe in the Audi/VW community, they tried the catch can idea and it showed not to help in restraining the carbon buildup. Now, that is a completely different engine compared to the new LT1 so again we'll see as soon as the new vette and trucks roll off the lines to see how bad it is.
Originally Posted by wssix99
I think BG addressed that pretty well and said the machining problem was on a single batch of parts from an outsourced company. That kind of issue doesn't show up in testing and every manufacturer has to deal with it. A widespread problem like BMW's DI carbon build up is a different kind of animal...
Not when engineers are breaking new ground or aggressively pioneering. In this case, others led the way, exposed the issue, and the engineers following have the opportunity to specifically address it.
If anything, I'd be more worried about problems no one has seen before.
1. A small batch?? I really don't want to sound like I'm trying to argumentative but the problem was not just a small batch that was quickly rectified.
The facts are the admission from GM is that the problem started in 2008 and was fixed by the 2011 model year. IMO, BG's statements are not 100% accurate on the matter.
2. I hope that you are right. Unfortunately, the truth behind all of it is that the auto manufactures are in it to SELL CARS and if the bean counters don't think a certain move makes sense, no matter how much the engineers think its important well... things get put on the shelf until someone can get around to it. Most unfortunate really... but it is what it is.
Old Jan 1, 2013 | 03:21 AM
obZidian's Avatar
Evidently from the buildup of oil residue from the PCV system since there is no longer a fuel there to act as a constant solvent. I was completely unaware of this, having owned a 335i in the past that ran awesome even as the mileage got high. I based my opinion completely anecdotally and stand corrected.
You know.... I didn't know much about all of this really until my cousin in law, after started working showed me some pics over some beers and I almost fell off the stool. I couldn't believe what I was seeing... those pics look like an engine that was completely neglected but then he told me how often he sees this and what they do to repair them, all under warranty.
That is the part that kills me... the manufacture(s) KNOW this is an issue however they continue to produce a "flawed" product and fix it by maintaining the flaw under warranty. At the end of the day it costs less to maintain the engines under warranty with some solvents and service hours, maybe throw in a few pistons and rings vs redoing an engine and addressing the real problem.
Old Jan 1, 2013 | 11:02 AM
wssix99's Avatar
Save the manuals!
This is a flaw of BMW and the German companies and the reason why I will never own one of their products. Once someone is out of warranty or decide not to go to their dealer for service, (you could also call it financial rape) they don't give a crap about the customer anymore. Not their problem...
My brother has a 335 and can't even get their Factory Service Manual. They treat it like some kind of top secret document and the dealers (we were told) are instructed to shred them when they no longer need them.
Old Jan 1, 2013 | 12:14 PM
Gordon0652's Avatar
Makes sense, I would think the "catch can" would take care of that. Nothing but air through the intake manifold.
But we will never know until it comes out and mileage is put on them.
Old Jan 2, 2013 | 01:13 PM
SoonLS1Powered's Avatar
The 2006+ VW GTI has this exact problem and there are a lot of those cars out there. From what I have read on the VW forums a catch can doesn't solve the problem. Its been said that the deposits are also from the accumulation of oil that slips past the valve guide seals.
Makes sense to me since no valve guide seal is going to seal perfectly, and small amounts slip past whenever the car is running, and probably the most when the intake manifold is seeing high vacuum.
Old Jan 2, 2013 | 01:34 PM
redtan's Avatar
Yeah, but is that enough to create such massive gunk up on the valves? Yes there are other ways for oil fumes to enter the manifold, but surely it can't be that much to really cause a sludge issue. And if enough oil seeps in from other sources besides regular PCV to cause such sludge then the engine has bigger problems than some buildup.
Either way, I personally believe that a healthy engine (one that does not have oil seep from these random seals) with a catch-can will be pretty much sludge free. Yes other issues can come up and cause such buildup, but then again these issues can happen on any engine even port injected ones like the gen 3/4 LS engines. The port fuel injection only really help keep the intake valve clean...anywhere else is open to sludge buildup in these cases where seals are busted for oil to seep in.
Old Jan 2, 2013 | 02:41 PM
sssuch's Avatar
Used to see deposits like this all the time back in the 60's-70's even into the 80's , seemed to go away with Port Injection. But the detergents in Gasoline probably had more to do with it. Back then anytime You did a valve job You had to bust off the carbon and coke with a chipping hammer and clean the rest of it off with a wire wheel. Sometimes it was so bad , you'd wonder how it even ran at all. I'm sure some of the other Oldtimers on here remember this.
Old Jan 2, 2013 | 07:16 PM
obZidian's Avatar
Very interesting. Thanks for sharing. You think that with todays fuels those older setups would have seen better cleaning when compared to the older fuels?
Im assuming these were engines with carbs right? The intake tract was seeing fuel however you had carbon build. Perhaps todays fuels do a better job at cleaning engine parts however removing the fuel before the valve will take all those advantages away.
Another interesting thing that I ran into was talks about the OIL itself being used and it having more or less of a viscosity "thingy" which results in more or less carbon buildup. I have to find the source to be certain however what is notable to mention is that the new LT1, at least not in the corvette will NOT run traditional mobil 1 syn oil. I wonder if the new oil has better properties that aid in not generating carbon buildup?
Old Jan 2, 2013 | 10:19 PM
wssix99's Avatar
Save the manuals!
This is a really great point. If there's no solvents running over the valves, they could easily collect crud that gets to them. I wonder if GM will have special procedures/tools to do top end cleaning for this engine? (All the methods I'm familiar with involve hooking up to the fuel rails or dumping chemicals in the fuel tank.)
Old Jan 3, 2013 | 12:00 AM
  #32
sssuch's Avatar
I think that most of the problem was the Fuel itself , it would leave gummy deposits in the fuel bowls and passages of Carburetors, PCV systems sucking up oil , EGR ,and Some of the problem was from oil that would run down the intake guides , compounded by the lack of detergents in fuel = carboned up Intake ports along with deposits cooked on the back of the Intake Valve.
In 84 - 86 I worked for Oldsmobile and We cleaned cloged Injectors on the Port Fuel 3.0 & 3.8 frequently. The problem seemed to go away all by itself part way thru the 86 model year. We found out it wasn't magic just the oil companys adding a better detergent package.
As far as this problem happening to the new LT1 I aint gonna worry about it . Big Guns and His team sound like they REALLY know what They are doing , besides it aint the 70's,or 80's, when the Customer did the durability testing.
Old Jan 3, 2013 | 08:31 AM
  #33
wssix99's Avatar
Save the manuals!
Did he go into how that might work? I believe this humps on the valve covers is part of the new pcv system. I wonder how that might work with a vacuum pump?
I guess time will tell then.
Just had a thought... If the PCV system is hooked up to a vacuum pump, the gasses can be dumped anywhere. No need to route them through the intake.
If the system is routed elsewhere, then the only source of oil that can get on the valves would be K&N air filters. (Initially, this comment started out as a lol, but after thinking more - it could be a small issue. I'll bet an oiled air filter is not a tested condition for GM engineering.)
Old Jan 3, 2013 | 09:19 AM
  #34
427LS7HCI's Avatar
I have a 2 buddies with 335s and no issues.
Old Jan 3, 2013 | 12:24 PM
  #35
obZidian's Avatar
You got me thinking... I went back and took a look at the new system with the pictures we have available from the press releases.
Take a look:
http://www.gminsidenews.com/forums/g...dium/GenV1.jpg
The line going back into the TB (traditionally on the passenger side on the LSx pcv setups) is now on the driverside and comes DIRECTLY from the valley cover. I don't think I see a check valve there but who knows.
Also, both valvecovers have fittings for lines on the front of each however I haven't seen any pics with those hooked up to see if they go to a pump or even how they are routed.
So what does this mean? I have no idea!!! But it's definitely different. I thought I saw once a pulley on the lower left of the accessory system that could very well be a belt-driven vacuum pump but again, I really don't know and haven't found that pic again.
What I do know is that we all have a lot of questions... hopefully they'll get answered soon enough.
Old Jan 3, 2013 | 03:47 PM
  #36
wssix99's Avatar
Save the manuals!
Yea, I think the new system is missing from all the display engines and we may need to see if they'll let us peek under the hood at the car shows this winter...
Old Jan 3, 2013 | 07:17 PM
  #37
obZidian's Avatar
The unveiling in detroit this january would probably be our best bet. Funny thing is that the wife and I have been toying with the idea of going up there for the unveiling but its one hell of a drive and on a weekday.
I guess I can wait for pics.
Old Jan 3, 2013 | 07:31 PM
  #38
obZidian's Avatar
Found it!!! It was right there in the home page of tech.
Looks like they both route forward, perhaps to the intake coming from the passenger side. The c6 z06 stock intake had a filter of some sorts adhered to the inside of the stock air bridge that supposively help catch some of the oil from entering the manifold. I wonder if that was revised and these are plumbed infront of that? And hopefully they used a better adhesive so we dont have to fish them out of the manifold.
Or they could be going somewhere else entirely. If those new valvecovers do the trick then hardly any oil should see its way back into the manifold and down the intake ports. Hmmm.. the more I lookduminto it the more im liking the new engine.
Old Jan 3, 2013 | 08:09 PM
  #39
Whistler's Avatar
Those pics of low mileage Audis remind me of the early 2000s Chrysler 2.7 V6 engines that had oil drain back issues from the top of the engine. These things were seizing left and right with 20-30k miles on them, and Chrysler was voiding warranties unless you could prove you had changed the oil in under 3000 miles every interval to avoid a recall of epic proportions.
http://forums.subdriven.com/showthre...?3730193/page1
Old Jan 3, 2013 | 08:27 PM
  #40
wssix99's Avatar
Save the manuals!
Does anyone know when they go in to production? There might be better looks at a factory tour in KY. Detroit is great, but IMO - bourbon country is a much nicer place to take in the local crafts and spend the night.
^ That diagram is interesting with the two lines disappearing behind that cod piece. I would have thought they'd come together closer to the block.
