Gen V part numbers
Wasn't exactly sure where to stick this.
Here are some part numbers for anyone interested. Not many have prices yet.
If you're looking for something specific let me know.
-Greg
L83 (5.3L) & L86 (6.2L) engine part numbers
New 5.3L long block - 12657207
New 6.2L long block - 12657206
ECM - 12656993
Intake manifold 5.3L - 12623417
Intake manifold 6.2L - 12639087
Intake manifold gasket 5.3 & 6.2 - 12626354
Cylinder head 5.3L - 12620210
Cylinder head 6.2L - 12620544
Head gakset 5.3L - 12622325
Head gasket 6.2L - 12622331
Intake valve 5.3L - 12619825
Exhaust valve 5.3L - 12619824
Intake valve 6.2L - 12629513
Exhaust valve 6.2L - 12629514
Valve spring 5.3L - 12619827
Valve spring 6.2L - 12629515
Valve cover Left - 12619980
Valve cover Right - 12619981
Lifter - 12576400
AFM lifter - 12619820
Camshaft 5.3L - 12619823
Camshaft 6.2L - 12629512
Connecting rod 5.3L - 12607475
Connecting rod 6.2L - 12654242
(Federal Mogul Pistons)
Piston 5.3L left bank - 12656877
Piston 5.3L right bank - 12656876
Piston 6.2L left bank - 12656875
Piston 6.2L right bank - 12656874
Crankshaft 5.3L - 12619781
Crankshaft 6.2L - 12623492
Prices are subject to change.
Update Added LT1 part numbers below
LT1 long block w/dry sump - 12657248
LT1 long block w/o dry sump - 12657236
Camshaft - 12629512 (same as L86) - $127.44
Crank (non drysump) - 12623492 (same as L86)- $559.67
Crank (drysump) - 12629940
Connecting rod - 12654242 (same as L86)
Piston left bank - 12656875 (same as L86)
Piston right bank - 12656874 (same as L86)
Cylinder head - 12620544 (same as L86) - $222.91 +$75.00 core (I'm guessing these are bare)
Intake valve - 12629513 (same as L86) - $15.83
Exhaust valve - 12629514 (same as L86) - $19.47
Valve spring - 12629515 (same as L86) - $3.51 ea
Intake manifold - 12629466
Throttle Body - 12620263 (same as L86) - $116.23
ECM - 12656993 - $313.68
Last edited by greg@paceperformance; Jun 12, 2013 at 03:25 PM. Reason: Corrected lifter part numbers & added corvette parts
Thanks Greg
Connecting rod cap bolts are the same as Gen3&4
Main bearing cap bolts carry over
Valve locks carry over
Valve spring caps carry over
Flexplate bolts carry over
peace
Hog
The heads shipped the same day they arrived right after we got pictures.
Most stuff seems to be available from GM now though.
