Why is it called an LT1, again?
And If you get any moisture in any distributor, it tends to not run well lol. This is not an LT1 specific issue, and humidity is a new one to me and I live in Iowa lol. If a car sat for a long time with moisture in the distributor it can rust cause issues of course, but the 95-97 are vented and tend to clear up very quickly if it's an issue (unless you park them in the back yard in the rain for a few weeks without starting it? idk) and the 92-94 optis are sealed so idk how humidity would even effect those at all. Either way, I'd file that under neglect. Same with an overheating or damaged leaking water pump.
I guess the majority of the LT1 section (people on here that have 100,000-150,000+ mile original opti's) all have total fluke cars. lol
The majority of people who have problems with an opti are ones who did something stupid with their car (drive through a river, power wash the distributor, replaced it for no reason, replaced it with junk, installed it wrong, the list goes on).
I've had my car for nearly 6 years and have yet to have an issue whatsoever with the opti, many can attest to the same.
Funny thing is, many times a cap and rotor will solve most issues, but people like to replace the whole distributor for some reason.
But either way, If spending several hours with simple hand tools to replace a $300-400 wear item on a 15+ year old car is too scary for you, then the performance car world probably isn't for you anyway.
People who insta-blame and bitch about the opti have a well deserved reputation too
The way you talk about them though is funny though. You sound like an idiot and you don't even realize it.
Rotors exploding? Didn't know rotors could explode... I'm assuming you're talking about when they're not tightened enough with loctite and they come loose over time? Give it a rest buddy, you sound like a jackass.
Anyways, back to the new LT1 engine, which is going to kick ***.
1). Buy Neglected car.
2). If car isn't neglected, neglect it (pressure washing the front of the engine is a good start)
3). Heater core clogs up, FM radio channels are fuzzy-blame the opti.
4). Replace the opti with a cheap aftermarket opti (bonus points for installing it wrong)
-See also "Pay Dealership to install opti"-
5). Wait for cheap Opti to fail
6). Repeat steps 3-5 as necessary
7). Get mad about money and time 'invested'
8). Sell LT1, Buy LS1
9). Talk about how much faster the mid 13 second car is than the high 13 second car.
9). Pat yourself on the back
10). Talk **** about LT1 on the internetz
AND LT1 f-bodies were NOT high 13 second cars lol. As many lt1 cars that ran 13's stock ls1's ran 12's stock lol. I know because I was the slow lt1 getting RAPED by ls1's. I had a mid 14 second lt1 and my friends 97 was a low 14 second car. AND they didn't take to mods well.
I'm not saying you're wrong on everything, but ls1's are MUCH faster and take to mods 10x better. I ran 13.4 in a 150% bone stock ls1 with 245 tires. Again I ran 14.5 in my 93 z28!
Same here..once that Tuning gets cracked...it's on.
And I find it funny how you imply I have a bias scope on things because I currently own a 95 (I've clearly never worked or been around anything other than my own car, right?). Your opinion is correct because you owned the total bastard year '93 car
I've seen Vipers and GT500's that can't get out of the 13's after 10+ runs at the drag strip. There's too many variables to argue about 1/4 mile times and modification responses over the internet and aint nobody wanna read bout dat anyway.
Sorry your old LT1 car sucked, but don't blame the opti son!
I love the Post by MasterTomos list of LT1 things to do... So true.
p.s. I dont hate the LT1, I actually like it alot more than the L98. I have owned several LT1 vehicles. My quam with GM changing the name was simply from a marketing brand name recognition stand point. They could have changed it to FOFF1 it would have made no difference to me. I just like that people who dont know much about cars often know what an LS1 is and what it means. Maybe GM did there research though and found out that sites like LS1 tech and thus alike were less visited than they were in the earlier years of the LS1's release. Maybe they figured new motor, new name, renewed interest and supporting internet traffic. Money makes the world go around so im sure GM have their reasons.
If GM won't step up to the demand, lets do it here. Any takers for branding names for the new LT1?
How about the "Zoom V8DI"?
My previous lt1 owner to do list went like:
1) buy lt1 car for more than i could have paid for an ls1 car, cause it only had 40k in 2007
2) immediatly have issue with opti, waterpump. replace.
3) replace clutch and add headers
4)enjoy car briefly, especially coming from a 305
5)another opti, stock replacement.
6)shift at 5800 one time, blow head gasket, warp heads, leaking oil.
7)head gaskets fixed
8)wont start. msd cap and rotor was no good, no idea why.
9)leaking oil from the front of the motor, little gear and spindle for opti had too much play, and was wiping out the seal.
10)a month or two after replacing opti gear and coil, fuel pump goes.
11)sold at 67k
2002 ls1 trans am. 165k, cammed, stalled. rebuilt tranny at 160k, due to incorrect converter installation. Other than that, zero issues.
11)sold at 67k
11)sold at 67k
11)sold at 67k
Yeah definetily out of the norm. My 95 Fleetwood with the LT1 had 51k on it when I bought it, 61k when I sold it. The A/C system had a leak in it, along with a weird electrical problem with the door switch that caused all the interior lights to come on when you hit a bump or shake the car.
IMO the LT1 was the strong part of that car, it was the lousy rust proofing on the frame of that car that caused me to sell it(it was a Michigan car BTW) I could slice thin pieces of rust off the frame with my big 15" flat blade screw driver right where the front roll bar and suspension parts mounted to the frame. Unless you crawled under it, the body. paint, and interior looked flawless, you would never know of the horrors that lurked on the underside.
