Generation V Internal Engine 2013-20xx LT1
L83 component images
Old Jul 9, 2013 | 01:26 PM
  #41
frankmarroquin's Avatar
Good Stuff
Old Aug 7, 2013 | 05:28 PM
  #42
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default L83 intake manifold
Just realized I never posted these to LS1 Tech.
Here is an image of the L83 intake manifold:
and another:
and another:
and here is a comparison to the L96/L93/LY6 intake (6.0/6.2L 2007-2013 trucks):
Old Aug 8, 2013 | 10:20 AM
  #43
ChucksZ06's Avatar
Interesting. Looks considerably lower...more like the car manifolds. Thanks for all the pictures of the engines components.
Old Aug 8, 2013 | 11:55 AM
  #44
greg@paceperformance's Avatar
The 5.3L intake looks much like the 6.2L intake. I'm guessing the main difference is the TB bore size
I also didn't realize the new intake was that much shorter.
Edit: All the location of the PCV nipple has moved on the 5.3L version
Old Dec 15, 2014 | 02:47 PM
  #45
cueball's Avatar
Does anyone have or know the cam specs for the L83 engine?
I need the LSA, duration, and lobe centerline numbers.
Thank you.
Old Mar 6, 2016 | 02:39 AM
  #46
Tomis's Avatar
Originally Posted by Jason Haines @ LPE
Here is an image of the L83 Gen V V8 engine cast iron crankshaft. 92mm (3.622") stroke, just like the previous engines. Weighs 53.8 lbs.
And here is the same crankshaft next to a Gen IV V8 crankshaft:
visually looks the same, are there any physical differences apart of key way? I came across used LT-1 stock forged crankshaft and I was wondering if it could fit in ls1 engine block? And another question, does anybody knows if LT-1 rods can be used in ls1, are they different by any means?
Old May 8, 2016 | 11:07 AM
  #47
fjrpilot05's Avatar
and another:
and another:
Hi LS1Tech,
New member here and New GenV L83 owner. Looking to educate myself on the new Small Block. I Went through all of the post Jason put up and I cannot access any of the pics.
Jason, did you have to pull them all down? It's too bad looks like you put up a lot of good information at one time.
Maybe I missed something because I don't see anyone else mentioning it. Could someone please enlighten me?
Regards,
Kevin
Old May 8, 2016 | 11:35 AM
  #48
LongIsland63SS409's Avatar
http://www.gm-efi.com/tech/lt1-camsh...aps-made-easy/
Mike
Old May 9, 2016 | 10:37 AM
  #49
fjrpilot05's Avatar
Hi LS1Tech,
Regards,
Kevin
