Generation V Internal Engine 2013-20xx LT1
Gen 5 LT1 swap
Old Oct 24, 2019 | 06:38 PM
  #61
TigerTruck's Avatar
Originally Posted by Rob94hawk
Will dig through the thread but just in case I don't see it, did you get all your gauges, speedometer, & tachometer to work? Thanks
I did it the easy way. I swapped out the dash for a Dakota Digital dash and used the OBD2 interface to get the speed, tac, oil pressure, water temp, alternator. All I had to do for the dash is wire in about 6 wires for brakes, Check engine, turn signals, lighting, fuel, power, ground. Not as hard as I thought. The dash came with all the sensors to tie into the engine but I really didn't want to deal with running more wires through the firewall.
I will officially get the car on the road in a few days but so far, everything works. All the gears work, reverse works, speed sensor works, dash works, heater works. I am currently working on getting the AC up and running. Wasting way to much on wrong AC fittings. That's basically the whole swap. Wasted so much money on excess parts including buying the wrong harness kit.
