GEN III parts in GEN V engine
Aside from a reluctor wheel change if a 24 tooth wheel, can the GEN III crankshaft work in the new GEN V engine?
What about GEN III connecting rods?
If not, what are the differences?
Pretty sure that they are vastly different than the previous 2 gens which were very interchangeable.
a close look at the GenV seems to show that the block is an evolution not a revolution.
same deep skirt 6 bolt mains, the rods are the same length as most LS1 aftermarket rods (6.125"), same bore as the LS3,A, and 9. same reluctor wheel as the late LS series?
The VVT system will probably be slightly different, the cam gear will probably be similar or identical.
there are a few things that can be shared, but most cannot.
The camshafts cannot be shared due to the direct injection and the reverse intake and exhaust feature of the head.
The crankshafts snout radius is different, as well as the how the flexplate/flywheel bolts
Rods are interchangeable, but pistons would need to be modified to work due to the oiling.
There is no way as of yet to remove the VVT from the LT1.
Heads of course are completley different
There are a few more differences, but nothing else major.
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I still need to find a buyer for my parts which are nice, and in the for sale section, and then move forward from there.
Besides... the stock GENIV internals are STOUT! Mine have seen many, many romps to 8000RPM and a couple over 9k ( one piston to valve issue ) but no serious piston damage so im still running the 100% OEM genIV short. Its been stellar
