Generation V Internal Engine 2013-20xx LT1
2014 L83 engine swap?
Old Jul 30, 2015 | 01:17 PM
GENIIIDude's Avatar
Default 2014 L83 engine swap?
In the middle of my swap and I'm still looking for some stand alone engine wiring harness info. I've got all the pin outs for the computer connectors just needing info on what needs fuses and power. Any help would be greatly appreciated!
Old Aug 31, 2015 | 10:51 AM
cam's Avatar
cam
I havent done a genV yet but the wiring should be pretty straight forward if you have the factory engine schems and pinouts. They will indicate what circuits are ganged together to bat and ign and how large a fuse and if a relay is required for each.
Old Oct 27, 2015 | 06:29 PM
frige's Avatar
I know this is a old thread but. Where can I get the pin out diagrams to build a harness for this engine?
Old Nov 5, 2015 | 12:00 AM
01WS6/tamu's Avatar
alldata
Old Nov 5, 2015 | 06:43 AM
frige's Avatar
I checked out the site alldatadiy.com Does anyone know what you get for your subscription? I found the donor truck listed for 26.95
Old Nov 28, 2015 | 11:01 AM
GENIIIDude's Avatar
Been away from this project for awhile, but I'm back on it. The jeep is close to completion, and yesterday I started the engine. All seemed good other that the VSS is reading 158mph! Tranny probably needs a "fast learn" done on it.
The wiring was more complicated than the previous LS version, but very doable. I'm sure I left things that could be deleted. The power steering was probably the most difficult thing to deal with. I built a mount for a jeep pump under the alternator on the pass side. I'll attach some pictures later.
Old Nov 28, 2015 | 04:08 PM
cam's Avatar
cam
Good to hear you have it fired. That 158mph VSS issue isnt new.... I STILL have that problem with my e38 GENIV swap but being a manual trans its not a big deal and its been running fine as is for a while now. Looking forward to your pics
Old Nov 29, 2015 | 11:40 PM
GENIIIDude's Avatar
Moving this discussion to here: https://ls1tech.com/forums/conversio...estions-2.html
Old Apr 25, 2016 | 03:26 PM
jamescallowa's Avatar
I've tried before but I couldn't find wiring harness anywhere before.
