Generation V Internal Engine 2013-20xx LT1
Lt4 crate engine pcv valve question
Old Feb 20, 2016 | 06:23 AM
Chandvogt's Avatar
Default Lt4 crate engine pcv valve question
Hi everyone! I'm new to the forum and am looking forward to learning from everyone.
I have a new gen V lt4 dry sump crate engine that I am installing in a 69 camaro.
My question is about the crankcase ventilation and the pcv system. I have read a lot about how the new z06 ingest oil through the pcv system and is cokeing the intake valve being that it's direct injection. I am aware of the catch cans out there but from what I understand they still feed some gases to the engine. Being that I'm starting from a crate engine I can start off however I want.
How would you guys go about plumbing the crankcase ventilation system so the intake never sees the oil and gasses?
Want to start out with the best solution. Thanks
Old Feb 20, 2016 | 11:58 AM
redbird555's Avatar
Really the only way to be 100% positive it never goes into the intake would be either to just use a breather and vent to the atmosphere or a vacuumpump
Old Feb 20, 2016 | 12:42 PM
Chandvogt's Avatar
That's what I was thinking but have few questions for each.
If I ran a vacume pump, would it affect the scavenge on the dry sump oiling system?
If I ran just breathers, would I have that oil mist everywhere?
What about the valley gallery port, would I just plug that on both cases?
Thanks for the help
Old Feb 25, 2016 | 02:04 PM
Project GatTagO's Avatar
Use the ProVent 400...
https://www.mann-hummel.com/fileadmi...nt_en_2013.pdf
Andrew
Old Nov 2, 2016 | 10:37 AM
MIGHTYMOUSE's Avatar
i know a guy that makes the only part available to handle this issue. pm me
