Vengeance Racing NA performance packages now available for 6th Gen Camaro!!!!!
Vengeance Racing is proud to announce the addition of 6th Gen Camaro NA Performance Packages now available on our website. https://vengeanceracing.net/packages-6thgencamaro.html.
These performance packages range from Stage 1 to our Stage 5 package.
Stage 1 starts at $1899.99 and consist of:
• High Flow Cold Air System
• 180* Thermostat
• Vengeance Racing High Temperature spark plug wire insulators
• Complete professional installation
• Custom Street/Dyno ECU Calibration
• Vengeance Racing Limited Warranty
• Color Print out of before & after dyno results
Stage 2: $3899.99
• 180* Thermostat
• 1 7/8” Stainless Longtube Header System with high flow catalytic converter connection pipes
• NGK High Performance Spark Plugs
• GM Exhaust Manifold Gaskets
Stage 3: $8699.99
• 180* Thermostat
• Vengeance Racing Custom Camshaft Kit- DELETED DOD/RETAINS VVT which contains:
- Vengeance Racing 8660 Billet Core Camshaft
- BTR .660" Lift Dual Valve Spring Kit w/ Ti Retainers
- Vengeance Racing 3/8" Hardened Pushrods
- C5R Timing Chain
- Bushing Trunion Upgrade
- CompCams Phaser Limiter
- GM VVT Cam Bolt
- GM Crank Bolt
- GM LS7 Lifter Set
- GM Lifter Trays
- GM MLS 6.2L Head Gaskets
- DOD Delete Plug Kit
- ARP Cylinder Head Bolt Kit
Stage 4: $10999.99
• 180* Thermostat
• Vengeance Racing CNC LT1 Cylinder Heads
• Vengeance Racing Custom Camshaft Kit- DELETED DOD/RETAINS VVT which consist of:
- C5R Timing Chain
- GM VVT Cam Bolt
- GM Crank Bolt
- GM LS7 Lifter Set
- GM Lifter Trays
Stage 5: $12999.99
180* Thermostat
MSD Intake Manifold- PORTED by Vengeance Racing
102mm Gen V DBW Throttle body
- C5R Timing Chain
- GM VVT Cam Bolt
- GM Crank Bolt
- GM LS7 Lifter Set
- GM Lifter Trays
Our performance Packages are set up on a Continuum setup that makes it easy for the person on a budget to slowly build their car and not have to dive straight into a big build. Feel free to contact us with any questions you may have regarding our packages or the performance products we use in our builds. We are getting ready to release our forced induction performance packages for the 6th Gen Camaro in the coming weeks. Keep an eye out at https://vengeanceracing.net/index.html for updates. We hope that you will choose Vengeance Racing and allow us to be the builder of YOUR dream car.
As always Like, Follow and Subscribe @
Facebook @ Vengeance Racing
Instagram @Vengeance Racing
YouTube @ Ronatvengeance
