Generation V Internal Engine 2013-20xx LT1
L83 power potential
Old Jun 16, 2018 | 03:19 PM
00pooterSS's Avatar
Originally Posted by Public Enemy
The cut outs alone added 25-30WHP So i guess its pretty restricted without have one.
Holy crap that's a lot. I've heard from a couple people that would know that headers add about 25 rwhp, so you're saying a cutout gave another 25 ish on top of that?? If so that's nuts to get that much power from just headers and opening up the exhaust
Old Jun 17, 2018 | 01:38 AM
Public Enemy's Avatar
yup.. before and after was tested. those gen v really like free flowing exhausts.. i also found that the 6.2 LT1/L86 have better power with 2 inch headers then 1 7/8
1 7/8 will work best with L83
Old Jun 17, 2018 | 05:04 PM
00pooterSS's Avatar
My plan was to do headers and search for a used 6.2 exhaust (3.5"). And then maybe do a better muffler in the 6.2 exhaust. From what you have seen do you think that would be enough to get the extra power you're seeing from the cutout? I've had my days with extremely loud exhausts, all of my fast cars in the last 20 years have been loud. This truck is really a luxury truck and I don't want it to lose that feel. And I want power but I don't want it screaming *** loud and still only be a 13 second vehicle, be different if it was a few seconds faster..
Old Jun 19, 2018 | 11:15 AM
I would do a 1 7/8 headers with 3 inch collector merging to 3.5" y pipe and then a cut out... keeping the rest of the exhausts stock and turn it on/off when you want.
If you are really concerned with being too loud.. then probably the 6.2 should work but i never tried it.
Old Jun 19, 2018 | 12:39 PM
00pooterSS's Avatar
That sounds like a good setup but I would likely do a used 3.5" exhaust from the 6.2 with a good muffler so the power would always be there and it wouldn't be too loud. Plus a good part of the money I spent on the cutout would likely cover the entire exhaust system. I just missed a used 6.2 exhaust the other day for $50...
I still have a hard time seeing a 50hp gain from headers and a cutout. That's crazy numbers.
Old Jun 19, 2018 | 12:56 PM
Only if the previous system was total crap, and most OEM systems in the last 10 years are not as bad as that.
Old Jun 19, 2018 | 04:45 PM
00pooterSS's Avatar
That's what I was thinking, I don't want to call anyone crazy or anything, but I have a hard time seeing that much power. But then again, I've been told by very reputable people that headers alone add about 25 to the tire, but that's headers I can more easily see why there would be power there. The other side of that coin is, how can headers free up 25 if the exhaust is that restrictive?
Either way, I've had a plan to do headers and 3.5" exhaust from a 6.2 truck, this just makes me feel even better about doing it. And if I "only" gain 25, i'll still be tickled.. because now matter how you cut it, 25 from an exhaust upgrade is big.
However, I'm weird, I also want to do the exhaust upgrades in hopes of getting a mpg or 2. If it don't no biggie, if it does then the exhaust paid for itself. But a couple of guys have said they saw an increase in mpg after headers.
Old Jun 19, 2018 | 05:00 PM
If a better exhaust gains 25HP, then I would say it's a slam dunk efficiency gains too, as all that power came without increasing fuel/air, just relieving backpressure AND tuning the pulses.
 Michael S. Palmer
Old Jun 19, 2018 | 05:38 PM
00pooterSS's Avatar
Exactly. And I try to make power through efficiency as often as possible, it's always the best way since it's always a win win win
Old Jun 19, 2018 | 05:43 PM
To me, power gain thru a better exhaust is free. I know the system costs, but this power involves NO extra fuel. It's just the engine not working as hard. Like you said.... win win win!
Old Jul 11, 2018 | 09:10 AM
Suprathepeg's Avatar
I'm not sure that is entirely true.
What your doing is allowing the system to exhaust more spent air/fuel more efficiently. When you retune for the better breathing you likely adding fuel to compensate.
Pumping more air for the same amount of fuel means the system starts to run lean and the ECU isn't going to allow that. I highly doubt the stock system out of the factory is dumping fuel into the motor that it can't get the best use of. Its not like the old days where engines were setup to run rich to compensate for bad fuel, timing advance etc. Now we have systems that are pretty advanced and able to run reliably on much tighter margins. Thus why you won't see a performance change without tuning to match.
Old Jul 11, 2018 | 10:27 AM
  #32
My point is, to get the same result power-wise, you have to hit the pedal harder with a restricted exhaust than a freer flowing one. MORE gas used...
Old Jul 11, 2018 | 11:11 AM
  #33
That's not really how it works.
Assuming you can move more air in the same amount of time allows you to add more fuel for that period of time. So if you're going to use 360hp to accelerate hard and then you do exhaust and intake work with a tune to support it you can now use say 400hp and get there faster you're also going to need to burn the added amount of fuel to get to 400hp. On the flip if you're on the hwy cruising and it takes say 100hp to maintain your speed the amount of fuel you're gonna use is the same. You may get a bit of a bump in milage from the efficiency gain you get from easier flow but I highly doubt its something you'd be able to notice in real life. Most tuners when they're tuning will also add a bit of timing and massage the fuel maps to lean out the rich areas, THIS will definitely net you a mileage boost.
All the benefit comes from the tuning one way or another. All the headers are doing is allowing you to burn more air/fuel. Remember these are DBW engines so the ECU is modulating how much the throttle body will open not your foot. Your foot basically says how much of the total available air/fuel you would like to burn at any given time.
Telling yourself you can justify the expense of headers with fuel savings on these motors is delusional in the real world. What happens is you get a bit better milage on the hwy because of the added timing and modified fuel tables, results you probably could have gotten without headers or intake. Then you put your foot harder into it under acceleration because you like the sound and seat of the pants experience more than you did stock, burning up all the fuel you saved on the hwy and likely more. Its chasing pennies with dollars...
Not saying there are no performance gains from headers but I'd be super skeptical of any fuel savings simply because you added headers. Your not doing it to get more milage anyhow, if thats what you really wanted you'd be driving a smaller vehicle with a smaller engine.
Old Jul 11, 2018 | 11:28 AM
  #34
You missed my point. Exhaust restriction is something an engine works to overcome by it working harder to push the exhaust out the pipe. This uses more fuel. This has been true even in carbureted engines. Yes, the mixture leans out with a freer flowing exhaust, but even after correcting thru rejetting, there is a fuel savings. Not much, but there nonetheless. And the harder an engine has to work, the more benefit a better exhaust shows.
And I agree, buying headers is a VERY expensive way to gain fuel mileage.
Old Jul 11, 2018 | 11:34 AM
  #35
Z28tek's Avatar
I have an L83 in my 16 Sierra Elevation (3.42 gears/tow package/trailer brake) and I love it, its a 6 speed auto, not the 8 speed but with the GU6 (3.42's) its a good setup, never owned a motor with Direct Injection until now. I am not touching mine besides a nice cold air intake, but I could see them making formidable power for a 325 cubic inch motor, the stock BHP number of 355 HP/383 TQ are impressive for a 5.3
Old Jul 11, 2018 | 11:55 AM
  #36
00pooterSS's Avatar
You guys are both right and I get both your points. Suprathepeg yes we understand more air in means more fuel needs to come in, but what G Atsma is trying to say is if you can do something to make the burn more efficient you will gain power and mpg. In this scenario since the stock exhaust is so restrictive it it causing you to use more throttle than necessary to make X power to roll the truck down the road. If you can make the burn more efficient then you can over come the excessive use of throttle for X amount of power. And in that scenario you open the throttle blade less letting less air in the engine but the burning of the fuel is more efficient so it now makes the some power output with less airflow. And I don't know who you're referring to chasing pennies with dollars, I'm not gonna do headers for MPG, I'm gonna do them for power and then I'm gonna smile when I see that I also gained a hair of mpg. Then I'll smile even more when I stomp on it and enjoy it. Then I'll smile when I can pass the gas station my buddy had to stop at cause he wanted to do gears to go faster and dropped mpg in the process..
Efficiency of the burn, not efficiency of the flow. Yes we are increasing the efficiency of the flow here but one aspect is the air quality in the cylinder due to better exhaust scavenging and less exhaust reversion back into the cylinder, and better cylinder filling over all. So we're now getting more power from the same amount of fuel, therefore less fuel can be used to do the same work.... cruise 70mph for example. If I can get more energy out of X amount of fuel, then I can use less fuel for the same work.
And as for headers being expensive, it's actually one of the lowest cost items that will add power and mpg to these trucks. By the way one of the top tuners in the world and I just had a conversation about this, he's seen mpg increases on these trucks from just a catback, I just noticed a small gain from replacing the stock muffler and flapper valve with a straight through magnaflow. The other ways to gain mpg is minimize waste through drag (on the body or drive line) or drop weight.. LRR (low rolling resistance) tires which are roughly $1000 for a set of good tires, a tune which is roughly $300-$400 and headers are also $400 for good ones (speed engineering). The other things to help are to do aerodynamic things to help with wind resistance, or things like electric water pumps, light weight drive shafts & wheels and tires, or crank scrapers. But LT motors already have a crank scraper (confirmed this with improved racing), the drive shaft is super light, the axles won't get much lighter, and I don't have 6k or more for forged lightweight wheels, so there isn't much left to do on these trucks that GM didn't already do. They adjust alternator output based on need, they went to electric power steering, they already have electric fans, they have variable output oil pumps, 4cyl mode etc to help with mpg.
