Generation V Internal Engine 2013-20xx LT1
Coolant and crazy 412 temp reading???
Old Jul 27, 2019 | 10:09 PM
Nicholas Root's Avatar
Default Coolant and crazy 412 temp reading???
Hey! First time posting anything and I hope I’m doing this right but I need help! Ok so..my 2006 LS2 6.0 would over heat, I’d watch the temp gauge jump up and down a bunch of times, I checked coolant, and added some. I need a water pump, but I replaced the water pump gasket hoping that I had a bad seal, I replaced the temp sensor 2 times and replaced the thermostat. I’m still leaking coolant out of the wheep hole. I thought the fans were not coming in but they are. The car sat for a month and when I checked the coolant temp on the dash before I started the car it read 412 and the temp gauge reads nothing at all??? I’m stumped...any advice would help
