Generation V Internal Engine 2013-20xx LT1
Question about turning over motor by hand
Old Aug 15, 2019 | 02:23 AM
jasonz28camaro's Avatar
Default Question about turning over motor by hand
I have this concern floating around in the back of my mind about my L86 motor. I inspected the valve train and bottom end to the best of my abilities while I had the valve covers and oil pan off. When I go to turn the motor over by hand with a ratchet wrench there is one area in each revolution that is a little easier to turn than the rest of the turns. This was done with the plugs out and on a motor stand by the way. I'm getting closer to starting the motor for the first time and I wanted to get some thoughts on this. I personally just thought it was the DOD lifters and nothing major because the motor only has 3500 miles and had no know issues prior to being pulled out for my swap. Would the DOD lifters make it feel a little strange/easier to turn the motor by hand if they have no oil pressure going to them?
Old Sep 21, 2019 | 01:33 PM
99RedHawk's Avatar
Sounds normal to me.
Old Sep 23, 2019 | 09:04 AM
Jimbo1367's Avatar
Hah, it’s been a while since we had a hand job” thread here. LOL
Old Sep 23, 2019 | 09:05 AM
Jimbo1367's Avatar
Default Hand job
Old Sep 23, 2019 | 09:37 AM
Good old fashion
Old Oct 4, 2019 | 05:32 PM
00pooterSS's Avatar
Yes it's possible
If you want to know for sure rip the rockers off, doesn't take much time at all and spin it with the plugs out.
Old Oct 13, 2019 | 07:53 AM
oldgoat69's Avatar
I would be more concerned if you found a significant "bind".
Like 00pooterSS says, remove the rockers and try again.
