Generation V Internal Engine 2013-20xx LT1
Anyone ever seen this LT1 cylinders?
Old Jun 26, 2018 | 06:22 PM
gearheads78's Avatar
Default Anyone ever seen this LT1 cylinders?
Bone stock 2016 LT1.The history was it was a car another dealership tried multiple times to get it to quit leaking oil since I can see the previous warranty repairs. The owner must have got tied of it and sold it or traded it in. The current owner did not know of the history and brought it to us for oil leaking. It was everywhere we cleaned it up and drove it seemed to be from the front cover. Replaced it and came back over an over until we have replaced several seals and gaskets. Finally tore the engine down and found this. You can feel these stripes they are terrible also feel like 240 grit sandpaper and causing so much ring seal problems crank case pressure it's pushing out oil from the seals.
EDIT zoomed in on the pic and its definitely a factory machining screw up. Never seen anything like that.
Old Jun 27, 2018 | 11:14 AM
Rob94hawk's Avatar
Wow. Those cylinders are dirty! Is that what direct injection does?
Old Jun 27, 2018 | 12:20 PM
MuhThugga's Avatar
Looks like a machining screw-up that slipped pass QC.
Old Jun 27, 2018 | 10:06 PM
That explains the leaks. The magnified lines are the boring bar cuts. For some reason the honing stones never touched that stripe in the cylinder. Weird. The rings got so filed down that there was little to no seal on that (maybe more) cylinder. Blow-by pushed the oil out anywhere it could go. Had to be down on power. I’d imagine oil temp was up also.
These are built by robots, so QC is spotty at best.
Old Dec 30, 2018 | 11:00 PM
rsz288's Avatar
Wow...yeah that sure slipped thru QC everywhere...the robot eyes obviously didn't catch it. And dealerworld couldn't figure it out either. :O
Old Dec 31, 2018 | 01:22 AM
383z's Avatar
No wonder GM is laying people off and saying it's not the quality of their products, but the shifting of buying habits.
Old Jan 2, 2019 | 05:49 PM
00pooterSS's Avatar
I've never seen that in my years. Pretty wild.
Normal for pistons to be that nasty looking. For any type of injection. Gasoline burns dirty.
Old Jan 3, 2019 | 07:15 PM
RockinWs6's Avatar
No way! those cylinders were smoking burnin oil, normal cylinders NEVER look like that!
Who ever taught you that is normal?
Old Jan 3, 2019 | 07:17 PM
pdxmotorhead's Avatar
I'd send that block to a good shop and bore EVERYTHING over again. (Cylinders, crank, cam bores)
It looks like a cutter change was missed..
Old Jan 3, 2019 | 08:18 PM
00pooterSS's Avatar
Big mouth.. small brain.
Old Jan 3, 2019 | 09:25 PM
01CamaroSSTx's Avatar
Well I opened my rings up a bit in hopes to some day run some NOS one day so I'd expect to see some of this wouldn't I?
Old Jan 5, 2019 | 01:01 PM
RevGTO's Avatar
Pontiacerator
Even though he's not original, I would hope the owner would get some satisfaction from GM, given the dealership repair history and that this is clearly a factory f-up.
Old Jan 7, 2019 | 09:47 PM
99 Black Bird T/A's Avatar
Wow, I hope GM takes care of that for the owner!
Monday engine build?
That robot was getting buzzed with too much high voltage AC current over the weekend.
Old Oct 13, 2019 | 08:07 AM
oldgoat69's Avatar
Bad calibration on the boring process. The hone didn't have a chance.
Carbon/oil on the piston tops is very normal. Even more so with poor ring seal. That would create a tremendous amount of blowby that gets sucked in by the PCV system.
