Generation V Internal Engine 2013-20xx LT1
L83 5.3 rod bolt torque
Old Jan 27, 2020 | 03:22 PM
mangrum09's Avatar
Default L83 5.3 rod bolt torque
I have looked all over and I can not find the connecting rod bolt torque spec? I also have not looked yet but I also need head bolt torque spec will I am asking for help. Thanks for the help!
Old Jan 28, 2020 | 07:35 AM
Old Geezer's Avatar
How about this? What you are looking for?
https://www.bing.com/search?q=Rod%20...704171307406C7
Old Mar 9, 2020 | 05:31 PM
00pooterSS's Avatar
Just looked it up in all data
Same as LS
15 ft lb
then 85 degrees
Old Mar 9, 2020 | 05:36 PM
00pooterSS's Avatar
Head bolts
Inner hex bolt (front driver head bolt)
First pass 59 ft lb
Second 90 degrees
Final 40 degrees
All other head bolts (standard hex)
59 ft lb
90 degrees
60 degrees
Sequence on the heads..
If you are looking down on the head with the exhaust on the bottom and the intake on the top (picture standing at the fender facing the engine... It is this below
..9 5 1 3 7
10 6 2 4 8
