Generation V Internal Engine 2013-20xx LT1
Weird Injector issue
Old Mar 15, 2020 | 04:34 PM
Blown Budget's Avatar
Default Weird Injector issue
Recently did an l83 swap into my jeep. When I did the first start up, I have been having P0206/08 issues. Swapped plugs, coils and wire to make sure those weren't the issues. Decided to pull the rail and went ahead and changed all 4 injectors in bank 2 because of the brute force I had to use to remove the rail. Probably wasn't needed but didn't want to remove it again...
Hooked everything and P0208 is still causing CIL and now I randomly have a P0107 code. The engine harness is brand new. The injector plugs under the foam is oem however. Is it possible this needs to be changed or could it be something else?
Old Mar 15, 2020 | 06:45 PM
After a few start ups, p0206 came back.
Old Mar 15, 2020 | 07:42 PM
Do you have a noid light?
