Generation V Internal Engine 2013-20xx LT1
No compression after valve seal replacement
Old Jan 29, 2021 | 09:08 AM
Rigred's Avatar
Default No compression after valve seal replacement
Just like it says I yesterday put new valve stem seal on my 5.3. Aired up each cylinder pulled the valve spring off swapped the seals then put everything back together starting with the aluminum bar the rockers ride on then each rocker. Rolled the motor over so each lifter was at its base circle then tightened and torqued each rocker. With all that done I have to compression. I double checked everything and I'm at a loss for words. Has any one seen this? Oh and its on every cylinder not just one.
Old Jan 29, 2021 | 10:38 AM
Valves are held open.
Old Jan 29, 2021 | 10:46 AM
Rigred's Avatar
I know that but why? All I did was took the rocker off and put it back on. I did turn the motor over with the starter with the rockers off so im wondering if the lifters pumped up and didn't bleed off when I put the rockers back on.
Old Jan 29, 2021 | 10:52 AM
See if any pushrods turn easily. How would the lifters pump up WHILE the engine is off AND disassembled??
You replace one seal or all of them? You mention them in the singular tense.
Old Jan 29, 2021 | 02:17 PM
RedXray's Avatar
You didn't happen to put the flat part of the trunnion into the rocker stand and the round part of the trunnion facing up toward the bolt?
Old Jan 29, 2021 | 02:24 PM
ddnspider's Avatar
Either you bought the wrong valve stem seals or you overtightened the rockers cracking all the valves.
Old Jan 29, 2021 | 02:35 PM
Fang's Avatar
Lifter plungers tend to live their whole life in one spot. Removing rockers allows the plunger to rise to the top, a normally unused part of the bore, where they can stick if there's any varnish/etc. built up. Reinstalling the rockers with the plungers stuck in the 'up' position results in the valve being opened instead of the plunger dropping back down.
Old Jan 29, 2021 | 02:46 PM
Rigred's Avatar
Thats what is exactly happening. I let it sit all night and this morning 4 of the cylinders came back to life after there lifters went back to normal while sitting over night. Its also pretty cold here so I set up my heater infront of my truck to help heat up the motor and help with oil not being so thick. This issue is definitely lifter related. Because everything is put together correctly. Im no novice by any means.
Old Jan 29, 2021 | 02:52 PM
Fang's Avatar
The 3100/3400 V6s, with the magic disintegrating lower intake gaskets, were TERRIBLE about this same thing. Most of the time it was only a few cylinders and it would still run after reassembly well enough for the others to clear up eventually, but I think I remember one that held the valves open enough to bend a few pushrods on first crank.
Old Jan 29, 2021 | 02:57 PM
Rigred's Avatar
Yikes
yeah this is only hanging them open a tiny bit just enough for the valves to not seal.. I know this because I had air in the cylinder and started Tightening down the rockers and once almost fully tight and cracked the valve open
Old Jan 29, 2021 | 03:46 PM
Rigred's Avatar
Its fixed and running. The lifter plungers were the issue. I heated the motor up with my shop heater then put the other rockers back together that I had off and regained 1 cylinder so i said screw it im going to try and start it on 5 cylinders. Fired right up and ran rough for about 45 seconds then started to clear up. She runs nice and smooth now with no issues. Thank for your input on the plungers cause I was pulling my hair out haha
