Oil pressure help
barbell is never an issue... unless its left out.
next item is did you get a clearances sheet from the rebuilder? specs?
what killed the original engine?
I tore a 4.3 this summer that had ran for 260k miles and my pressure had fallen to like 7 psi at idle. The cam and rod bearings were gone. Clearance was around 4.5-5 thousands when checked with a micrometer and dial bore guage. I'm just learning how to take measurements, so that was a good exercise for me.
You can use Plastiguage on the main/rods, very economical. Not sure how you would check clearances on the cam w/o a mic/bore guage. You can always take it to local machine shop for measuring, if that's an option.
I've seen the "tool," and it is two metal tabs that go into the timing cover bolt holes that you butt the new oil pump against.
What I have done is match the outline of the old pump mounting points on the block.
If you put the pump back on with the rubber inserts on the bolts, there is little to no movement at all...
Anybody had a problem with low oil pressure after an oil pump change on one of these engines?
Oh, I also just realized those engines have a little solenoid on the oil pump. The pump itself is now a vane-type, and resembles the pump of the 4L60e, instead of the gerotor of Gen III/(IV?)
Correct it is called a VDOP oil pump, they have been around for decades. They are actually used by all OEMs now. Main gallery feedback is a powerful lubrication tool, unlike the older Gerotor pumps that relied on pump out pressure for regulation.
thanks!!
I have been reading and studying the LS1 oil flow diagrams.
I believe that leaving the dog bone out will not cause lack of oil pressure, the oil flow is just diverted into oil filter then continues up the oil gallery. If dog bone is left out the oil flow just continues on its intended path. Yes my dog bone is installed.
I am chasing no oil pressure on startup also. I have mechanical gauge in the sender location and front main galley at oil pump.I have primed twice using 3 qts using air over oil and also a pump. I have started and run for about 10 seconds, no pressure and no oil at rockers. I have removed pan and checked fit of o ring, seems to fit well using green o ring. Back together and no dice again. I have new Melling oil pump and new cam bearings and within spec on mains and rod bearings, standard size. I ordered the 2 o rings from melting but just can’t believe that would be the cause zero pressure even if the wrong size was installed. If the black ring is larger diameter then the green one I will try the larger one, regardless no pressure??
I am tempted to pull pump to see if pressure relief is stuck open some how, I am a very capable SBC engine builder including 383 strikers. This is my first Gen 3 engine, every thing was done professionally. Frustrated.
welcome your input.
welcome your input.
