L86 cam swap broke cam dowel pin
Like stated I did a dod delete on a 15 l86 for a customer. Been a while since I've dove into these lt engines. I always pull motor and do the swap etc. On this one I messed up the dowl pin on the cam.
Can the cam be removed without hpfp removal? If not can the lower fuel pump piece beneath the valley cover stay installed? Ive always removed all this on a swap and this issue has me in a pickle.
