Group Purchase Requests Please post your GP requests here for the sponsors to consider them.
ATI Damper GP?
Old Jun 28, 2009 | 01:18 PM
  #81
2000_SS's Avatar
Originally Posted by 1FASGTO
Anybody know what the difference is in the 918853 and 917242?
918853 is for blower setups, 917242 is the OEM diameter pulley with an A/C pulley, which is what i have minus the A/C pulley. the 918853 pulley would be, I THINK, for a cog drive procharger setup or something similar. email ATI with any questions you have for definitive answers, they're VERY thorough and informative
Old Jun 28, 2009 | 01:35 PM
  #82
99blancoSS's Avatar
I have 1 .... 917276 left... 10% UD w/ac
and 1... 917271 LT1 10%'ish
Old Jul 5, 2009 | 12:58 PM
  #83
2000_SS's Avatar
anybody here have any pictures of the hub installed on their crank? mine isn't going on the way i imagined it would and i'd like to see exactly what it's supposed to look like.
Old Aug 20, 2009 | 01:11 PM
  #84
airforcemanss's Avatar
can you pm me the price of the gp deal. 10% w/ AC. whats the difference with these dampner with AC and no AC? mine is a true street car but it will see a decent amount of track time for fun so should i stay with a 10%? its not a dd if that matters
Old Aug 20, 2009 | 01:33 PM
  #85
99blancoSS's Avatar
with new front seal $430 to your door 10% with a/c
Old Sep 11, 2009 | 04:28 PM
  #86
The ATI Serpentine Super Damper contains grooves for serpentine belts machined into the outer damper shell. The dampers come standard with 6 outer grooves for standard OEM drive systems. 8 & 10 grooves are availabe for supercharger or turbo applications.
this is messing with me. i thought the super damper would be fine the way it is? do i need more grooves with my 8 rib setup for my d1sc or will it be fine because it seems that i need more grooves for my supercharger setup and i keep seeing this in the part description for this damper?
Old Sep 11, 2009 | 06:27 PM
  #87
kkslds's Avatar
I could be wrong but i think its pertaining to systems that run with the rest of the accersories that might be upgraded to 8 rib ie.magnacharger,kenne bell, etc. Systems that dont have a designated drive belt
The pulley will be fine the way it is if you are running a procharger style setup. Just bolt your blower crank pulley to it and go. Hope that helps
