Group Purchase Requests Please post your GP requests here for the sponsors to consider them.
Autotap GP???
Old Aug 13, 2002 | 03:18 AM
sited12's Avatar
Default Autotap GP???
Is there one going on or could one be started. Really want to get autotap and looking for a great deal.
Old Aug 13, 2002 | 08:13 PM
00ws6ta's Avatar
Default Re: Autotap GP???
same here
Matt
Old Aug 13, 2002 | 08:18 PM
Jon @ Speed Inc's Avatar
Which versions were you looking for? You can get the AutoTap Hardware and AutoTap for Windows with OBD II Generic Parameters all the way up to AutoTap Hardware and EFILive V5 Pro with bi-directional controls ....
Also the palm piolt software.
Old Aug 13, 2002 | 11:40 PM
sited12's Avatar
Definately the windows version. Not really sure about the other options. Probably the best there is.
Old Aug 13, 2002 | 11:44 PM
sited12's Avatar
Could we get a deal on the hardware windows and EFI live set up.
Old Aug 14, 2002 | 10:16 AM
EFI Live or EFI Live Pro? Retail difference is $50 to have bi-directional controls
Old Aug 15, 2002 | 12:32 AM
sited12's Avatar
Probably the Pro. It sounds cooler. But could you explain what the differences are. Also what would it run total.
Old Aug 15, 2002 | 11:47 AM
Retail is $354
I'll see what I can do
Bi-directional controls that come with PRO
Controls
Idle speed - Sets the idle speed to an rpm value in the range 0-2040 rpm.
IAC - Sets the idle air control pintle position to a step value in the range 0-127
Gear - Sets and holds the currently selected gear to one of
First
Second
Third
Drive
Injector Off - Allows the operator to perform an injector balance test by selectively turning off individual injectors. Only one injector will be turned off at any time.
Switches
M.I.L. - Illuminates the Malfunction Indicator Lamp. This feature is not available on some vehicles.
Shift skip - Illuminates the Shift Skip lamp where fitted. This feature is not available on some vehicles.
CC inhibit - Inhibits the cruise control from operating.
A/C clutch - Turns the Air Conditioner compressor clutch on or off.
Fan 1 - Turns on low speed thermo electric engine fan(s).
Fan 2 - Turns on high speed thermo electric engine fan(s).
Lift/Dive - Turns Lift/Dive compensation on or off.
A.I.R. sol - Turns the Air Injection Reaction solenoid on or off.
A.I.R. pump - Turns the Air Injection Reaction pump on or off.
Fuel pump - Turns the fuel pump on or off.
Fuel learn - Turns fuel learn mode on or off.
Closed loop - Sets fuel mode to open or closed loop.
Rev lockout - Turns reverse lockout on or off - manual gearboxes only.
TCC - Engages or disengages the Torque Converter Clutch - automatic gearboxes only.
Modes
Use spark map - Overrides the PCM's normal spark advance by substituting the values found in the currently loaded spark map.
Use fuel map - Overrides the PCM's normal air fuel ratio by substituting the values found in the currently loaded fuel map.
Evap service bay test - Puts the PCM into a mode that allows evaporative emission controls to be tested.
Fuel trim reset - Resets the learned fuel trims.
Tooth error learn mode - Puts the PCM into a mode where it can learn the crank tooth error correction
Old Aug 15, 2002 | 07:23 PM
justin sutton's Avatar
I would possibly be interested in atap also keep us posted please.
Old Aug 17, 2002 | 08:36 PM
glhoot1's Avatar
i'm in if the price is right <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Aug 17, 2002 | 09:12 PM
Right now Larry is checking into it for me...I know that we don't have any instock right now.
The rest of the month and September will be hectic over at Speed Inc -- we are moving down the street in very early November...we need the space badly.
I'll keep everyone posted.
Old Aug 20, 2002 | 03:33 PM
sited12's Avatar
any new info on this?
Old Aug 20, 2002 | 04:11 PM
no word yet. next time I talk to larry I will ask.
Old Aug 22, 2002 | 04:37 PM
ls1290's Avatar
Dumb Ass Vette Moderator
I would be in for the windows enhanced version. Will have cash in hand and mor ethan ready to spend tomorrow( 08/23/02 ) <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
