Ported Heads
And yes we will need your cores back or $500 core charge will apply.
Nate
<small>[ November 30, 2002, 12:24 PM: Message edited by: Nasty N8 ]</small>
Nasty Performance stage1 heads-fully hand ported and polished, bowls cleaned up, multi-angle valve job, new valve seals, and Comp Cams 918 springs.
Reg. $1400 Intro $1100
Nasty Performance stage2 heads-fully hand ported and polished, bowls polished and shaped, 2.02in 1.60ex Valves, heads cut for Comp Cams double valve springs, new seals, milled for compression.
Reg. $1900 Intro $1600
6.0, 5.3, LS6 also available
Custom ground Comp Cams cam to match $375.00
Thanks Nate Bonham
<strong>And yes we will need your cores back or $500 core charge will apply.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Does that include LS6 heads <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
How much more for 2.08" intake valves and 1.460" spring seats? I have the valves and springs.
Nate
<strong>Nate, I will drop you a line later on today to discuss this <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks be hearing from you.
The stage 2 depends on the application street or race and and cam being used. But usually around 270cfm@ 28psi at .550lift. We retain as much volocity as posible and make excellant power under the curve and lots of lowend TQ.
Nate
<small>[ December 11, 2002, 01:18 PM: Message edited by: Nasty N8 ]</small>
