Group Purchase Requests Please post your GP requests here for the sponsors to consider them.
Synergy 2 step for 6 speed n/a cars
Old 04-22-2007, 04:06 PM
  #101
WS6FirebirdTA00's Avatar
Ups
Old 04-24-2007, 07:05 PM
  #102
anyone get theirs in the mail yet? I am curious as to how many wires there are
Old 04-24-2007, 09:11 PM
  #103
Adam98Z's Avatar
Didn't get mine in yet.
Old 04-25-2007, 07:25 PM
  #104
SS-ROB's Avatar
should be here by Friday!!!
Old 04-25-2007, 07:29 PM
  #105
mine is in g-boro right now
Hopefully Santa II comes a day early haha
Old 04-25-2007, 09:38 PM
  #106
MetallicaMatt's Avatar
friday for me as well
Old 04-26-2007, 03:50 PM
  #107
mine just showed up today!
i win!
Old 04-26-2007, 04:05 PM
  #108
Mine should be here today too I hope.
So how many wires are there
Old 04-26-2007, 04:20 PM
  #109
15 plus a ground lol
Old 04-26-2007, 05:04 PM
  #110
Just got mine in. Not as bad as I thought. Figured there were going to be a million wires.
Now time to hook it up.
Old 04-26-2007, 08:50 PM
  #111
post some pics when you get it in. where are you mounting it?
i wont be wiring mine for a few weeks at least
Old 04-26-2007, 09:09 PM
  #112
it is under the hood, I was going to put it in the glove box, but I didnt feel like adding length to the wires.
Everything is good except for the fact that it called for me to go to wire C1-35, which I do not even have. I am going to have to set up a relay for the clutch switch it looks like.
Old 04-27-2007, 08:04 PM
  #113
I will see if I can get some pics tomorrow. I JUST finished up the install.
I had to run a wire through the firewall to the clutch switch (upper one) and put a relay there. I really dont see how this works on other f-bodies because they all show the same pin out from what I have seen, but my instructions called for a pin 35 which was empty.
If you guys are planning on doing it soon, real quick, you need to splice into the grey wire on the upper clutch switch (compressed when clutch is out) and put that on 86 of a 12v relay. This is the normally open contact. Then you need to put a switched 12v power to 85 and jump that to 30 (all these numbers are on the relay). Then hook the grey wire for the 2 step up to 87a, the normally open contact.
You can put this under the hood, but it was easier for me to lengthen one wire and run them inside. I wish now that I could have put it all inside, but its not a big deal.
Old 04-27-2007, 08:16 PM
  #114
SS-ROB's Avatar
If I'm not mistaken C1-35 is for a Corvette clutch switch.
For the F-body it should be number 32 gray wire. I'm going to double check to make sure.
Old 04-27-2007, 08:30 PM
  #115
yes you are right.
Old 04-28-2007, 08:48 AM
  #116
Well I know who I will be pestering when I go to install this!
I am completely **** about messy wires, I like to hide everything. So this'll take some planning
how are you splicing into the other wires? or just connecting them into the pin?
Old 04-28-2007, 10:00 AM
  #117
I cut and spliced them. I was told to solder them, but I am not the best at that so I did not go that route. If it ever messes up I will have one of my buddys come over and do it haha.
I used 18-22 gage splices, and they are in there tight. Then I went and taped some up. I did not finish yet, because I want to make sure I do not have any other issues. Once all is good I will most likely clamp them down on more time and tape them all up individually.
I like to hide everything too, which is why I am not a big fan of having it mounted under the hood. I drilled one hole where I mounted it, instead of 2. Only problem I see is the cables to the TCS motor are resting on it, but that should not cause any issues.
What I may do once I have it all set like I want it, is cut and lengthen the wires OR mount it behind the PCM if there is room.
Old 04-29-2007, 03:33 PM
  #118
here are some pics. The switch needs to be fixed. I tried to put a rectangle in a circular hole lol. I will prob order a new piece and do it right. I had another switch there for the EWP when I first got it. I also have another switch I may use.
The LED is my own I got a while ago. I like it a lot better, lot smaller. I put it under the foam under the gauge cluster. There is pleanty of room to mount it behind the PCM, so as soon as I set it how I want it, I will put it back there and hide it, because I just dont like the way it stands out under the hood right now.
Attached Thumbnails Synergy 2 step for 6 speed n/a cars-1.jpg   Synergy 2 step for 6 speed n/a cars-2.jpg   Synergy 2 step for 6 speed n/a cars-3.jpg
Old 04-29-2007, 03:42 PM
  #119
BOTTLEFEDLS1Z's Avatar
Damn Mike your car is clean under the hood!!!
Thanks for the input so far. I'm doing mine sometime this week.
Old 04-29-2007, 03:51 PM
  #120
thanks man, thats why I want to get that box hidden so bad lol.
If you guy have any questions/issues just hit me up and I will help you out.
Quick Reply: Synergy 2 step for 6 speed n/a cars
