Holden Performance Australian LS1 Powered Vehicles
If you haven't tought much about the oil galley Barbell check this out!
Old 11-30-2016, 04:39 PM
LS1Tech Sponsor
saccitycorvette's Avatar
LS1Tech 10 Year
Default If you haven't tought much about the oil galley Barbell check this out!
SacCityCorvette's
Precision LS Billet Barbell and other Oil System Improvement products!
The Oil Galley Barbell in your LS based engine is something that is over looked. And yet it serves a very important mission of directing oil to the oil filter. If oil leaks past the Barbell it will go unfiltered directly to the Cam Bearing, Lifters, Crank and Rod Bearings. (See Diagram Below) The factory Barbell is approximately .020” to loose so particles as big as 500 Microns can leak past the factory Barbell. Your oil filter will filter out 15 to 25 Microns depend on the brand of filter. Our 7075 Aluminum Precision Billet Barbell fits with approximately .001” clearance which will let only about 20-25 Microns pass by, that same as the filter.
Another important part is the shaft of the Barbell. The oil has to flow around it to get though the oil port. Our Billet Barbell has a 30% smaller shaft for much less flow restriction.
We have also added a 1/4-20 threaded hole in the end of our Barbell for easy removal. Just screw a 1/4-20 bolt in and pull the barbell out. No more digging and prying to get the factory one out.
Better engine protection from much less and smaller particles bypassing, smaller less restrictive shaft for better oil flow, replaceable High Temperature Viton O ring and for ease of service a threaded 1/4-20 hole.
Why would you ever put the plastic factory Barbell back in your expensive LS engine build?
See Our other Oil System Performance Improvement Products below.
Fits LS1-2-3-6-7-9-LQ4-LQ9-4.8L-5.3L-6.0L-6.2La and more! Also available for the new LT1/LT5
Only $26.95 Free Shipping
http://www.saccitycorvette.com/Billet-BarBell.html
Here you can see how the unfiltered oil gets by the loose factory Barbell. Also you can see how our Barbells smaller shaft will improve oil flow!
Check Out all 4 of our Oil System Improvement products!
If you don't know much about how the Barbell works check out video.
Video of how loose the factory Barbell really is compared to our billet Barbell.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 02-22-2017, 06:32 PM
LS1Tech Sponsor
LS1Tech 10 Year
Must have for that new build!
__________________
Old 03-18-2017, 07:06 PM
99wssixm6's Avatar
Looks pretty sweet! Post in the general tech section for more viewing.
Old 03-19-2017, 07:25 PM
LS1Tech Sponsor
LS1Tech 10 Year
Thanks for the kind word and the good advice!
Christian
__________________
Old 03-19-2017, 08:30 PM
samckitt's Avatar
Why not put an O ring at both ends?
Old 03-20-2017, 11:25 AM
LS1Tech Sponsor
LS1Tech 10 Year
Hi samckitt,
We experimented with a O ring on the front. The problem is that the oil ports that the O ring has to slide by are very sharp and slice chunks off the O ring. That's probably why the factory one doesn't have a O ring.
Thank you,
Christian
__________________
Old 01-20-2018, 11:17 PM
Nick V.'s Avatar
Old 01-21-2018, 03:02 AM
LS1Tech Sponsor
LS1Tech 10 Year
In case you didn't notice they are all under different topics that you subscribed /searched.
__________________
Old 10-16-2019, 12:00 AM
LS1Tech Sponsor
LS1Tech 10 Year
We have all these Billet Parts and the AlignIt Tools in stock and ready for same day shipping!
Billet Oil Improvement Parts, Help unfiltered oil out of the bearings and lifters.
https://www.saccitycorvette.com/OilS...provement.html
AlignIt Tools, get the rear Main and Timing Covers perfectly aligned with the crank and prevent leaks and premature seal failure!
https://www.saccitycorvette.com/AlignItTools.html
__________________
Old 04-23-2020, 02:03 AM
LS1Tech Sponsor
LS1Tech 10 Year
We hope everyone is doing well and staying safe during this crazy time of the virus.
Just wanted to let you know, while we are practicing the virus safety precautions, we still have our same day shipping of our products.
Stay safe and let’s get through this!
Christian
SacCityCorvette
__________________
Quick Reply: If you haven't tought much about the oil galley Barbell check this out!
