Is it true the Monaro will get
<strong>Holden currently fully import the engine/transmission straight from USA in FBody spec. They don't pull the motor apart (except for warranty <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ) all they do is have different exhaust manifolds, intake pipe & computer changes (more conservitive).</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What did u car dyno at? U have an LS1 engine right? Is it Auto or M6?
Last time I gotit tuned it made 205 RWKW,
That doesn't mean much cause your Horse power is rated different to ours as well so best comparo is 1/4 times/speeds.
Our Holdens weigh approx 3,900lb's with a driver.
Stock they cover the quater in 14 - 14.5 sec range with trap speeds of 97mph - 101mph in std street trim.
Last time out I went 13.5 @ 105mph 2.2sec 60'
Only changes were shift kit auto, exhaust, CAI, and reprogrammed computer.
Next time out will be with 3200 Vig and U/D pulley.
After that I will have my TR 230/224 cam and further tuning.
<strong>Over here or Dynos read in RWKW(rear wheel kilowatts), Mine prior to tuning made 160 RWKW.
After that I will have my TR 230/224 cam and further tuning.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So ur telling before tunning when it was totally stock it made 160RWKW*1.34=214RWHP!!! That is really a shitty PCM. After tunning only 205RWKW=274RWHP without any parts?? What did u dyno after the exhaust,CAI, tunning?
13.5 at 105 with a 2.2 60ft is great. For sure after the TC ur going to shave another .3-.5 from ur time. And the cam will put u in the 12's.
Also have to remember that we use different dyno setups as well pretty much all eddy current style.
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by v8 ute:
13.5 at 105 with a 2.2 60ft is great. For sure after the TC ur going to shave another .3-.5 from ur time. And the cam will put u in the 12's.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You would probably find that the HP level you are quoting would be on the conservative side as our dynos calculate the HP at a different (lower in numerical value) to the USA setups.
I'll see if I can find out a conversion rate for this.
