LS Fest 2013 Whos going!!
How tight is the inspection on roll cages? What will be my ET limit in a '69 Nova with an 8-point roll bar?
I already have c-clip eliminators, driveshaft loop, extended wheel lugs.
So what would it take for me to be allowed to run in the 9s?
EDIT:
So this means I will not be able to participate in Real Street since I have an aftermarket front subframe in my '69 Nova?
EDIT:
Originally Posted by "holley.com'
Suspension Front: Aftermarket bolt-on replacement front K-members are allowed (if front shocks bolt to
K-member then they must be in factory location). For 1974 and earlier model years, OEM strut
tower/shock tower may be removed in lieu of installing/using commercially available suspension kit. (IE
Heidt, Fat Man, Alston, Smith Racecraft etc) with a 50 pound weight adder. Stock front frame rail
required. Front frame rails may be modified or removed 10in forward of the OEM K-member attachment
point.
point.
LS1TECH & Trucks Sponsor
Before long those who skip this will figure out what they have been missing and the answer to who will be coming next year will be EVERYBODY!
This event rocks and SDPC will be there again for sure!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
EDIT:
EDIT:
9.99 1/4-mile (6.39 1/8-mile)/ 135 mph or quicker:
-Roll cage is required on all vehicles at 9.99 and quicker or any vehicle running 135 mph or faster (regardless of e.t.). The roll cage must be constructed of a minimum o.d. mild steel or chrome moly tubing (moly can be a smaller o.d and is lighter but more expensive), see diagram below for specs. Roll cage must be padded anywhere the driver's helmet may contact it while in the driving position, see diagram below for specs. Roll cage must also be certified by NHRA every 3 years and have a serialized sticker affixed prior to participation. This style of cage is good til 8.50 1/4-mile times, then a funny car style cage is required.
See diagram below.
-Window net required (can be ribbon or mesh, no altering allowed unless done by manufacturer. 2009 NHRA rule book states mesh nets carry a manufacturer date and a 2 year expiration/re-cert, while ribbon are good forever. Check with your local track or division).
-NHRA competition driver's license required, done by car designation (dragster, door car, etc). A physical, 2 NHRA licensed drivers to witness/sign your forms and a minimum of 6 runs are required. For NHRA license form click here: www.nhra.com/contacts/forms/licenseapp.pdf, for NHRA physical form click here: www.nhra.com/contacts/forms/physical01.pdf
-Flexplate SFI 29.1 and shield SFI 30.1 required (no expiration dates listed, but I believe the shield is 5 years)
-Protective Clothing (SFI jacket and pants with a 3.2A/5 rating, gloves and neck collar, no expiration date)
-Battery cutoff (regardless or whether battery is still up front or relocated to rear of vehicle). The cutoff switch must shut down everything electrical when off; see here for pictures and a wiring diagram: http://www.ls1tech.com/forums/drag-r...ct-switch.html
-A full-face helmet is required with a minimum Snell K98 or M2000/SA2000 rating. Helmets last 12 years from their rating date (example a Snell 2005 would be good until 1/2017). Shield is permitted, and modifications to helmet or shield are prohibited. This rule posting is as it applies to cars like ours (closed body type). For open cars a different helmet ruling is required.
John - it looks like my Nova wont qualify for the Real Street class since I have a Martz front subframe.
Do they really require an NHRA drivers license to run 9s even in the True Street class? I know I'm whining but there is a significant list of upgrades that I'll need to meet NHRA rules. Things like my harness and helmet expiration date, updated jacket, driver's license... I'll just have to evaluate the cost or slow it down to run 10s. But who wants to slow their car down.
#36
I am from Bowling Green and my father retired from Holley so its really cool to get my dad out to the track. He raced his 59 pontiac back in the day right there at beech bend. My car is at Vengeance Racing right now but it will be done in time for the LS Fest and I will be coming over from central Missouri. See yall there. 2002CETA
#37
I'll be there, and in my usual fashion I will bring a car to beat on like its free, and my camaro.
This years victim-strict budget fox coupe with a junkyard 4.8 and s475 turbo. Its not going to be setup for autox or speed stop, but i'll do it anyways, its always a blast. See yall there
