Parts FS at LSFest! Post them up!!
EDIT: Unfortuneatly I am most likely not going to make it to LS Fest but I may be able to send the parts with someone who is going.
Off the top of my head (I need to check the parts shelfs) I have available
BMR (MTA001) Full Length Adj CM Tq Arm. -- $250
BMR (TCC006) Tq Arm Relocation Kit for M6 -- $150
BMR (MPHR002) Panhard Bar -- $100
BMR (PHR004) Panhard Rod Relocation Kit -- $100
BMR (XCA001) Lower Control Arms -- $150
I have all of the stock rear suspension parts as well -- Make an offer?
Fans -- $50
Radiator -- $40
LS1/T56 Stock Bellhousing -- $50
Fans -- $50
Radiator -- $40
I have a set of Weld pro stars for sale. 15x10-7.5bs $250
4.8 crank checked and polished- $100
Stock front knuckles with brakes and calipers- $100 for the pair
New rear drilled and slotted rotors- $80
Trick flow crank pulley. Keyed- Part number TFS-18005. $130
Flowmaster axleback for 2013 Camaro ss- $450
Could bring any of the fallowing parts.
coan th400 setup complete for ls1. 5K vert, CSR sheild, cooler, lines, dipstick, deep pan. SOLD.
Champion 15x10 Beadlocks for a mustang. Cap 5's with double x lock rings. Like new rims only SOLD.
QFT 950 race carb, no choke, annular boosters, flows 1150cfm. $500
241 heads $150
Moroso 3 vane vac pump setup, pump lines and tank. $700
Mazeire race water pump that bolts to block. No pulleys, race pump. $300
Truck manifolds, $100
Impact 3 layer pants and jacket, very nice, white piping, xxl jacket and adjustable pants. $300
Bandit helmet all black clean lens, $175
Nano 4500 bottle and refill valve, three nitrous bottles setup for nano. $700 for all of it. two bottles full.
28x12.5 ET street bias tires. Very little use at all. $175
If anyone wants any of this I can bring it with me. Just PM me.
241 heads $150
3" exhaust tips
SOLD!!!!!!!!!!!!!!!!!!
I have this listing in Parts FS for $30 but I can bring to the fest if anyone pm's me.
I have (2) Cherry Bomb stainless steel exhaust tips that are about 1 year old. These sell for $26 each at Jegs plus shipping. As you can see in the pictures, I had to cuts slits in them to slip over my 3" exhaust pipes. You can clamp them on as I did or weld them on. They are 8" long and have a 3" inlet and 4" outlet.
I have a few parts if somebody needs them i will bring if they need them if not i will just try and sell on tech call or text me 256 303 5225 thanks.
Becool alum radiator that came with flexalite thin fans $300 came out of 3rd gen.
Drag Air bag set up for rear springs for fbody $30
5.3 long block with bad rod. has no intake or anything just heads down. $300
harland sharp rollers for ls1 1.7 they been ground for clearence not hurt. $200
#34
Stuff for sale
I can bring this stuff if anyone is interested.
-2014 Camaro SS wheels w/ center caps new. $500 Obo.
-ls7 intake manifold w/ fuel rails $150
-ls7 throttle body $150
-ls3 intake w/ rails and injectors $350
-ls7 valley cover $30
-2014 silverado/sierra intake manifold-$100
-2006 gmc sierra for sale or trade for 4 door ls powered car. $14,000. Fully loaded. Brand new wheels and tires.
Call or text if interested or if you want pics of anything. 205-757-7769
#35
The following parts I bought during a sale at the Summit Store. This sale included returned,scratched, discontinued, or possibly missing items. In full disclosure, I will do my best to describe the items, but please keep the above info in mind. If you want more info or pictures please message me.
-ASP Crank and Alternator Pulley for LS1 Part# ASP-948584 Price 160
-Moroso Billet Water Pump Part#MOR-63566 withLSx Adapters Part#MOR-63566, Two gaskets for pump to adapters appear to be missing and there is some light scratches List price for these are 640! Price 425
-Summit Gear Set 3.73:1 for GM7.5/7.625 Part#SUM-741011 Price 110
-AEM Tru-Boost Controller Part#AVM 30-4350 Price 225
-Summit LSx Balancer Part#SUM-C2520 Price 125
-ARP Head Bolts LS9 Part# ARP 230-3701
-Musclecar Oil Pan Swap Kit Part#NAL-19212593 Price 125
-Comp Cams LSx Manual Tensioner Part#CCA54021 Price 100
I purchased new this new and only used it about a month.
-MSD LSx Plug n' Play 2 Step Part#8733 Price 160
#36
Pm sent
