LSFest 2015 "Buy sell trade"
#42
>ls1 241 heads without springs $100obo
>set of ls1 rockers
>lq4 truck intake with throttle body (broken port on top.)
>truck exhaust manifolds
>valve covers
>ls6 valley cover with built in pcv $70obo
>new gm RH mirror for camaro
>camaro washer tank
>front and rear engine covers
>2002 disassembled ls1 engine with most gaskets needs piston rings! $800obo
>poly motor mounts
>red tail light panel
>red z28 spoiler
>radiator fans
>eibach sportline springs $130obo
>stock z28 red hood
>chrome stock z28 wheels chrome pealing
>stock front shocks and springs from z28 and rear shocks and springs 138,000 miles
>Sensatrac front sturts with spings and rear shocks
>two 255 fuel pumps ran for 20 minutes then went to twin 450s ran e85
>boost ref fpr -6 inlet -6 outlet -6 return ran 20 min and went with new regulator with bigger ports ran e85
>corvette exhaust manifolds
I probably have some more stuff... Need it all GONE. make me a fair offer on anything. We all know what this stuff is worth
>set of ls1 rockers
>valve covers
>camaro washer tank
>poly motor mounts
>red z28 spoiler
>radiator fans
>stock z28 red hood
I will take the right hand mirror if you still have it?
#44
Parts are from 5th gen Camaro with less than 10,000 miles.
Eaton TruTrac - 9" Rear 31 Spline DSS inspected - $250
BMR Poly Subframe Bushings - $75
BMR Adjustable Sway Bar with End Links (Red) - $150
Weld RTS Wheels Polished 17X8 and 17X10. Fronts have new Pirelli P-Zero. Rears have 40% tread left on MT ET Streets - $2,000 will not separate
Front and Rear Leather SS Seats (Black/Beige) - $1,000
Rear Trunk Mat (Orange SS Logo) - $75
RPM Level 7 4L65E with Transbrake/SFI Housing - $2,500
Billet Underhood Dress Up Items - Misc.
If anyone wants anything, please let me know because I may not haul it all with me.
#48
I have a few things I am going to bring, sold most at Norwalk cp shootout.
champion aluminum 4th gen radiator
texas speed billet alum 100mm MAF housing for ls3 sensor
summit 10% UD pulley/balancer for ls1 fbody/gto
drilled/slotted front rotor off my 1996 Camaro, new
4th gen plastic gas tank with complete EVAP.
2ea Weld Draglites 15x10 BS 7.5 not the fbody specific. bought for the gto
Kooks 2004 gto catless mids
12 bolt rear end out of a 1970 monte carlo,
#49
My dad had a 2010 camaro mgw shifter and orange speed dawg camaro ss shift ****. Asking $375 for both, used less than a year before he had rpm auto swap his car. Shifter is 350 plus shipping new, **** is 80 plus shipping new.
#51
Got 2 sets of 799 heads complete $350/set. Aluminum 5.3 short block 85k. Dod went bad only thing wrong with it. $400 will not bring unless serious. Camshaft 54-446-11 what is wrote on snout $200.
#52
i will be looking for a cowl hood for a C5 and wheels for a c5. Looking for RTS or something like that.
Also looking for a clutch for a c5. a twin disk would be nice!
And maybe a blower set up for a c5.
i also have a custom comp cam and 7.400 PR i can bring.
236/242 601/610 114.0
very little miles, no issues.
#56
I have:
new 229/229 Cam. 620" 600" lift for you turbo guys $300 free shipping
new BTR 660 lift dual spring kit (steel retainers) $200 free shipping
Slightly used (2500 miles) tryo treated ls3 rocker arms with BTR trunion kit + new BTR rocker bolts $345 shipped.
Ferrera inconel exhaust valves for LS3, L99, L92 style heads $120 shipped.
looking for:
fast 102 intake manifold for LS3
102 mm throttle body
new/used harmonic balancer (ATI)
text me @ 504-270-7831
or message me at devonpwalker@gmail.Com
willing to do package deal
looking for:
#57
NOS 3 bolt nitrous plate and lines that go to solenoids and all mounting hardware and gasket $100
LS1 3 bolt throttle body ported and painted by me $40
#60
I just registered for LS fest so I'll be coming up with my 2005 C6 wide body and I have some parts for sale
Complete LS2 Longblock takeout from my C6, 24x completely stock, have intake fuel rail and 42lb injectors as well
Stock LS7 clutch works great I only took it out because I swapped to a nitrous motor and put a Mantic into hold the extra power
(2) 325/30 ZR 19 Goodyear supercar run flats in good shape
I have a set of JRZ shocks That will fit C5 and C6
