New guy with a Jeep
. Right now I own a 1998 5.9 Limited jeep grand Cherokee that is highly modified. Im looking at getting an LS car and thought this is a good site to learn from. heres a couple pics of the current ride. Built by me, not a shop.
And I dont want to post ***** or post in any tech threads because I dont know any tech on these cars yet, now if you have a ZJ question I know them inside and out
I've got an '89 YJ - 383 Chevy, Holley EFI, TH350, Atlas 4 speed TC, D44/12 bolt with 5.13 gears and detroits, 37" IROKs with Staun internal beadlocks, high steer, full cage, 5 point harnesses, stinger, MileMarker 12K winch....
That's why I ask for your definition. The above is my idea of heavily modded
So you can **** further than me..... Its still a D44 and 12Bolt on 37's
.......For a Grand Cherokee it is pretty modded. Trending Topics
As for my D44/12bolt.... They're both running moser shafts, which are significantly stronger than the stockers. They're holding up fine. 14 bolts are too big. Even if you trim them, they're still going to hang on the rocks.
So now im looking for a replacement, theyre so cheap!! Seriously, you can find plenty of the 96-98 Grand Cherokee Limiteds for around $3000. 5.2 of ocurse, 5.9's are rare and when you find them they are twice as much. Are you on Jeepforums? i have a ton of questions about zjs first being how do you find headlight replacements? Does anyone make projectors for them? can you put a double dinn nav in the factory stereo slot?
). What other mods are you planning? Differential gliders? Roof rack? That front bumper is bitchin. As for my D44/12bolt.... They're both running moser shafts, which are significantly stronger than the stockers. They're holding up fine. 14 bolts are too big. Even if you trim them, they're still going to hang on the rocks.
Dont hate, different is always good
PM me with any questions you've got and Ill be glad to answer them for ya. also check out www.nagca.com or www.mallcrawlin.com those are two Grand Cherokee specific boards with vast amounts of info.Ive also considered bringing it back down to stock and racing it at the drag strip, lol
ARB Winch Bumper-$1000
5" Rough Country Lift-$800
Rubicon Express Front upper adjustale control arms-$200
Brand new 33x12.5x15 BFG KM2s-$1000
Black D-window Cragar Rims-$250
Doug Thorley Headers, 3" pipe all the way back, High Flow cat, Magnaflow large body Muffler-$1000
Vanco Big Brake Upgrade-$800
New European Spec Glass Headlights-$300
New European Spec Turn Signal Lights-$100
Mopar Performance ECU-$300
Kevins HD Radiator Support-$200
WJ RB1 Navigation Headunit with integrated IPod Controller-$700
Clear Corner Lenses-$40
Old Man Emu SS-$120
JKS Quick-Disconnect Swaybar endlinks-$160
Rugged Ridge HD Inverted-T Steering setup including new tierod ends-$300
As of May 22nd 2009 I have installed more parts to include:
Front windows tinted 20% to match the rear-$100
JKS Rear Adjustable Tracbar-$200
New OEM parts include:
upper spring isolators, front bump stops/bump stop cups, front axles (new, not rebuilt), hitch (new OEM), hitch harness (new OEM dealer installed version), tail lights (Crown OEM replacements), rear pads/rotors (Performance Friction Carbon Metallic), front brake lines (Goodrich stainless steel), cooling fans (new OEM), radiator cap (new OEM), rear wiper motor (Mopar rebuilt), hatch struts, hatch glass struts, hatch glass release button, license plate lenses (has LED lights in it right now), rear track bar, overhead console (new OEM), shifter **** (new OEM), carpet (new OEM), console lid (new OEM), transfer case shifter assembly (new OEM), shifter bezel (new OEM), TC bezel (new OEM), steering column upper/lower trim (new OEM), cluster bezel (new OEM), steering wheel (new OEM), headlight switch (new OEM), heated seat/rear wiper switch assembly (new OEM), turn signal multifunction switch (new OEM), seat belt adjuster ***** (new OEM), spare tire cover (new Bestop), front/rear/cargo liners (new CatchAll), speakers (new 6.75" front/rear doors, 5.25" sound bar, Infinity Kappa), head unit (new RB1), battery (new Interstate), passenger/driver's side kick panel trim (new OEM), rear passenger side quarter panel trim (new OEM), DDM (used OEM), key fobs (used OEM), keys (new OEM round-head), center console cup holder insert (new OEM), faux wood dash trim (new OEM), brake pedal cover (new OEM), emergency brake handle (new OEM), tilt steering **** (new OEM), under hood insulation (new OEM), front corner lights (new aftermarket clear), front turn signals (new aftermarket EU), There's more, but that's all I can think of for now.
Haha, thanks man! im currently looking to trade it for an LS1 car, so what ya got? :D PM me with any questions you've got and Ill be glad to answer them for ya. also check out [url
Are you considering selling it ourtight? How much are/would you ask and how many miles? What stat are you in btw?
