1996 Chrysler Ciruss LXI 2.5 6clyn Hessitation
Hello
I am new to this site and I have a 1996 chrysler ciruss lxi. This car has a hesitation issue when taking off once it gets up and going it runs fine intell i stop at a light then same issue it acts like its going to die but doesnt.
Things that have been done. New fuel Pump new fuel filter, new cap and roter , new wires, new plugs, new injectors new map sensor new air control sensor, new idol sensor new ignition switch, Recently ran sea foam through the system. Engine light came on says it had a cylinder mis fire and it seems the rear o2 sensor is not reading corretly and possible tcm issue. Any thoughts were to go next. I am going to see if the converter is ok and search for a vacum leak. Should i change out the TCM Relay before dealing with the transmission control module. Help.
UUUMMM not to make fun but you aren't on the right forum for your car. It isn't even a GM product...but that is ok you said your rear 02 isn't reading correctly then it sounds like you may have figured the problem out yourself. Change the 02 sensor see if that fixes it and if it don't come back for more help. Welcome to the site.
^^^ don't listen to this guy. rear o2 is only there to test your catalytic converter performance, nothing more. you car will run perfectly fine without rear o2;s. the front o2's are a different story.
Oh I must have misread that but if his rear 02 isn't reading right and he still has a catalytic converter then possibly the cat is clogged. We both know that clogged cats can cause all sorts of problems.
