New from AL
so since you all have been so helpful i figured i'd join.
Names Greg, From Huntsville, Al and I have a
98 Trans Am lq9 6ltr swapped.
Comp Cam
worked heads
Straight cut timing gears
Entire clutch system from a '02 Camaro SS w/ drill bit mod
Spec Stage 3+ (full disc)
pro 5.0 short shifter
4:11 Gears w/ auburn locker
Edelbrock Long tube headers
off road y pipe to a 1 chamber race flow master then dump
C5 z06 wheels
Eibach sportline 1.8in lowering springs
UMI upper/lower control arms
UMI Pan hard rod
at work now so no pics yet. will post up tonight.
pics for now ---> www.myspace.com/thephantom616
Anyways Oxford here nice to have you.
you should come to the strip in Hunts. on the 31st! a bunch of us will be there..
**i had the pewter TA with ws6 hood running 7.4s.. girlfriend was in her black TA running 8.4s.. had a couple other buddies there..
EDIT::: looked at the pics.. that was you! did you run it? what times?
