Need conservative LS1 rebuild advice
Love my 2000 Z - it has 145K miles to-date. Test drove a 2010 Challenger RT and was so disappointed in the performance (soft transmission and buffalo-like handling) I decided to dump 18K into my Z and start over. I'd consider a 2010 Camaro but I use a wheelchair and the '10 Camaro is not conducive to wheelchair in-and-out. All my motor work will be done by others.
The only mod I have on LS1 is an SLP Flow Pack. My question is: In order to build up the horspower to 400 or so and loose a max of 4-5 mpg accross the board what do I do? FAST intake, bigger MAF, LS6 heads, MSD Blaster Coil, headers ... I really would like a recipe so to speak for a tried and true configuration.
I will be adding a Borla Cat and beefing up my automatic trans and purchasing a Diablo programmer when I do the motor.
Elwood
Elwood
With 18K to blow i would not shoot for 400HP. I would probably shoot for double that with almost 20K to spend lol. IF you want to spend 18K on your Z get a new Forged LS1, Trickflow heads, a cam, Fast92/92, An overkill transmission build, a 9inch, Complete suspension setup, 200 shot wet kit, ect ect lol
what color you painting it and what wheels you looking at?i'd go for jetstream blue metallic with ccw lm20's.as for the engine 400 is really conservative.go for 450hp with a torquer v2 cam,fast 92/92 setup,prc stage 2.5 5.3 heads,and a yankss 3600/4000 stall.thats what my setup is going to be and im sure there are many others with the same.that with a full suspension and a 9inch rear would be very nice.
