squid!
Old Jul 10, 2010 | 08:46 PM
saltwaterreefguy's Avatar
Default squid!
Hey there...
My names Jesse. Just bought my first ls1/t56 car (00 SS) slp sticker and all. Super excited. Picked her up for 1800 bucks in running condition. The car was in a front end collision and whomever put it back together really didnt care about the car. I plan on bringing the car back to life. Anyways I have a couple of questions....
The fuel pump is actually going out and I was wondering what you guys recommend I replace it with.... I'm planning on doing heads and a cam (nothing outrageous). I just want to see what you guys recommend.
and 2
I want to not drop the rear end so I have been reading about the pump install cutting the back I have a grinder so I plan to use that. What do you guys patch the hole with?? Thanks.
Old Jul 10, 2010 | 09:08 PM
bad_408_vert's Avatar
You don't have to drop the rear in your 00 to replace the pump.
I replaced it w/ a dealer part, so I ll let others chime in.
Old Jul 10, 2010 | 09:26 PM
I wouldn't enlighten me...
Old Jul 10, 2010 | 10:08 PM
Searching4Sierra's Avatar
when i did my pump i just covered the hole with the piece i cut out, and then put some dynamat over that......i wasnt really going for looks
Old Jul 10, 2010 | 10:37 PM
alright sweet.... can't find my grinder... fml
Old Jul 10, 2010 | 11:28 PM
you can use a cut-off wheel too if youre careful
Old Jul 10, 2010 | 11:43 PM
does this sound like a fuel pump before I get started....
I can hear the fuel pump "prime" then start the car fires not everytime but almost, rough rough idle almost like its cammed and then dies. If I press the gas pedal its almost like it dies quicker. I gave it a couple sprays of starter fluid and it runs longer.
I depressed the fuel rail and no fuel is coming out. I changed the fuel filter and no change. Thanks again for the info.
I know will probably get moved to a different section now. Haha.
