6.0
Old Nov 3, 2012 | 12:55 PM
trjk07's Avatar
Default 6.0
hey everyone,im new.let me say im impressed with you alls knowledge of ls motors.i have a 98 trans am that getting noisy.i have a lq4 motor with 317 heads.and a set of 806 fully ported heads and a 600 lift cam with close to stock duration.what can become of all this in the bird?
Old Nov 3, 2012 | 02:40 PM
MonmouthCtyLS7's Avatar
Pretty general question man, there's a ton of factors....but 806's are older perimeter bolt heads....The 317 truck heads are similar LS6's but with larger combustion chambers...Id say your best bet is to sell the 806's and send the 317's out to get worked...depending on what intake your running and the type of trans id say 400-425 to the wheels is attainable.
Old Nov 4, 2012 | 07:18 AM
trjk07's Avatar
okay thanks.its a 6.0 out of a 04 denali.what about cleaned and freshened with the 600 cam and the ls1 intake and a tune.decent power like what is there with the 5.7?
Old Nov 4, 2012 | 08:09 AM
30th t/a's Avatar
if the 6.0 ran when you bought it, I wouldnt mess with freshening anything. Just install the cam, matching pushrods & valve springs.Id just get the 317s milled to bump your compression up. LQ4s only have 9.4:1. Get the milled enough to get to 11.1-11.4:1 compression.
With a good cam, 11.1CR, headers & catback, & a LS6 intake, and a dynotune, you would be over 400rwhp.
Im running a stock LQ9 6.0 (77k on it) which come with 10.1 compression from the factory. All I did was install a baby LS6 cam, LS6 springs, LS6 intake, cheap pacesetter headers & a slp catback and it put down 380/380 with the 3.90 gears. Runs great and drives 100% stock.
Old Nov 4, 2012 | 09:19 AM
trjk07's Avatar
wow,kinda makes it cheap to build.im used to the old school 406 and such.thanks for the info man.most helpful
Old Nov 4, 2012 | 09:49 AM
Yea around the same power, little more torque and of course the motors a little heavier
Old Nov 4, 2012 | 08:34 PM
ssnovaturbo's Avatar
FYI if its an 04 denali 6.0, its an lq9
Old Nov 5, 2012 | 07:27 AM
trjk07's Avatar
May be off on year.has a lil dish to pistons
Old Nov 5, 2012 | 10:23 AM
Mgill's Avatar
Im running a cam only lq4 with 241 heads, ls6 intake, headers and exhaust and made 425 rwhp. Car went 11.88@119 full street weight on a tire.
Old Nov 5, 2012 | 10:44 AM
trjk07's Avatar
nice.im learning quickly these ls motors are almost no limits.im trying to use what i have.any thoughts on a thin head gasket.03 z06 cam and ls1 intake.trying to make around the same power the ls1 had is all
