240z LS/LT Motor Swap
Hello im 24 my name is Josh im going to be getting a 71-73 Datsun(Nissan) 240z. Im wanting to do a LS/LT motor swap but not sure which motor would be best? Im wanting to make the car a strip car and make it also a Daily Driver(maybe) any advise would be very appreciated my name is Josh thanks for your time
I will try to find some photos of the cross member. we made a cradle the motor sat into from tube steel so the sump could sit in and low.
We (a fabricator bloke I know, all credit to him for this bit) done this by making a jig from a factory cross member and cutting, grafting and gusseting the cradle into it. Factory engine brackets where used with vertical straight through type mounts between the factory LS1 brackets and the cross member - It makes sense in my head, not sure about others. When I find pics it will make sense
1 - 10 is hard to say. 2/10 for the project technical details as it was simple stuff into an old car, however mounting the motor was a solid 8/10.
I had a look for pics of cross member and cannot find any Will post if I come across them.
