LS Swapping my S14
A little about myself, I live in Central Ontario. I bought a 1995 Nissan 240sx with a stock manual 2.4l engine. I drove the hell out of it all winter and decided I would begin an LS swap in it. Since June when I took it off the road, I have pulled the engine, sold it, removed everything from the engine bay, Painted the bay, Patched a hole in the wheel well and a large hole in my floor and Frame rail.
So far my LS swap purchases include:
2000 5.3l Lm7 with questionable mileage and car accessories
Daft Mount Kit
Sikky Power Steering Conversion lines
Full OEM Wiring Harness and ECU
Walbro 255 Fuel Pump
Canton Racing Swap Pan and LS pickup
I will throw something tech related in my introduction if you guys don't mind. I have searched far and wide about using a tr6060 in my LS swap in the 240 and the conclusion people come to is "they are too expensive and not worth it." But i have found one in my area for less than $2000 CAD and i can't find a t-56 under $4000 so I am going to go ahead and buy it. I am buying it tomorrow so if anyone has any reason for me not to, please chime in by tomorrow. I am under the impression that all I need is a 2.5" shifter relocation from Tremec and a custom driveshaft (obviously)
The TR6060 will need a slip yoke for the Driveshaft, shortened DS, and the Sikky shifter or custom shifter relocation. Consensus is that for all out racing the T56 is better but for daily use the TR6060 is much smoother.
And one more piece of advice...some fuel kits and/or people choose to use the Russell Quick Disconnect Type Fittings when setting up their fuel system...DO NOT use them. They can pop off under high fuel pressure demand. Use the Screw on Type.
http://www.dennysdriveshaft.com/p327...on_slip_y.html
https://www.sikky.com/view_item.php?id=201&catid=13
Use the bottom Screw On Type:
http://www.jegs.com/p/Russell/Russel...19594/10002/-1
but i have a zenki with an ls3 and tr6060...i could not find one person running the tr6060 in a 240, only lots of talk about it. i did manage to get mine up and running with it. for my drive shaft, i just took the measurements and told the shop what trans and rear i had and they built me one. its going to be aluminum for the splicer part and need a plate to bolt to the trans that they shop should have or can get. and then my shifter im just running a MGW for a 5th gen camaro and made it work, but i had to cut about 2 inches back...but it does fit perfect with the console and shift boot on. and i had to make the transmount cause no one has one for tr6060 into a 240
