Newbie to the forums .. Looking for help with build
Old Jan 28, 2016 | 09:21 PM
XtremeWorkz's Avatar
Default Newbie to the forums .. Looking for help with build
What's up.. New to forum .. Looking for info on build ... 2001 WS6 t-top TA.. Auto car.. Will be driver fully loaded a/c power everything( except brakes probably) staying over drive trans .. Will be doing single turbo kit.. And help pics will help.. I suck at searching forums don't have lots of time to play on net so sorry now if I post question already asked 1000 times
As of now car is bone stock red 73,000 mile car
Installing and already have-
BMR 4 point frame connectors
BMR 1" lowering front lower control arms
BMR tubular upper control arms
BMR turbo tubular k member
BMR Xtreme adjustable rear control arms
BMR adjustable torque arm with drive shaft loop
TRZ anti roll bar/ pan hard bar
Need - 9" rearend housing (thinking 3" narrower with 15x10 wheels with 5.5 backspace) *need help with this want to run widest rim biggest tallest tire without mini tubing
Will post pics as I go!
Nice meeting everyone and all help and suggestions welcomed!
PS I have to warn you I'm a smart *** and out going so I'll try to be good!
Attached Thumbnails Newbie to the forums .. Looking for help with build-image.jpeg
Old Jan 28, 2016 | 10:44 PM
107 views not one comment .. lol friendly bunch!
Old Jan 29, 2016 | 05:52 AM
TrickChassis's Avatar
Welcome! I make 9" rear ends in house. Im in beloit Wi you could come and check the shop out and i can show how and what your housing and components could look like. http://www.trickchassis.com/index.ph...ing-with-axles
Old Jan 29, 2016 | 01:04 PM
TrickChassis thanks! Might check it out! Will go to site and look around!
