New guy...
Old Mar 23, 2016 | 04:04 PM
Ss-96's Avatar
Post New guy...
What's up guys and gals, I'm new on the forum and I'm from Louisiana, I'm currently working on a swap into a 96 single cab and I'm really looking for help with how to I splice my old harness into my new harness so my gauges and everything work
Old Mar 23, 2016 | 06:02 PM
76larkman's Avatar
welcome to site. What harness your trying to tie in? What the donor?
Old Mar 25, 2016 | 03:51 PM
Ss-96's Avatar
I'm trying to get all my basic gauges from my 96 Silverado tied into my 02 Avalanche harness, but I can't find a wording schematic anywhere except all data but I can't get access to it. I need to know what color wires from the LS harness I need to tie into what color original gauge wires for them to work properly.
Old Mar 25, 2016 | 09:29 PM
76larkman's Avatar
on my square body chevy I have a 89 suburban harness I started with. I used a lot of what was there for pcm power(had 2 to old pcm) that's what new needed. I had fuel pump fuse already so used that to trigger relay. For temp and oil pressure I used the sbc senders. Just bought adapters on ebay. Speedometer should tie in as well. I also used the original hot wire to coil to power the key on/key run/cranking as it stays hot. I got a 95-05 cavalier under hood fuse box wired it in. 2 rows of fuses in it. I took apart made 1 row to the coil wire talked about, other row to positive battery constant power. I used the fuel pump relay in that box too. The way Lt1Swap.com wires in the relays and fuse blocks I didn't do. Instead all the wires connected to what I had or cavalier box. I think your truck probably has all curcuits needed, just figure it out.
