Researching for a swap
Having said that, my mind has always been on V8 four door cars for everyday. Problem with most American V8 cars is, they're heavy. My solution; find a suitable Japanese car to swap an LS into. Simple right?
Ive gone back and forth on this. I particularly wanted a Gen IV LS so I could pair it with a 6L80 to get the best drivability and fuel mileage, as it's a daily. Problem there, from what I've read, it's a little fat and will be difficult to fit in most platforms. So, I believe I'm going to settle on an LS1 with a 4L80 and see how I like it. Eventually, perhaps I'll get the TCI 6x 6 speed transmission with the 4L80 casting. But, that's big bucks so we'll see.
Im debating between the IS300 chassis, or an RX-8 chassis. Both cars have kits available. The RX-8 is a bit more readily available for a good price. The Renisis rotary engine is a poor design and they're dropping like flies. You can pick up a decent rolling chassis for as little as a thousand bucks. It's crazy how cheap they've gotten.
Anyway, it's good to be here and I look forward to my build. How soon that happens, will depend entirely on what kind of deals I may find out there. I'm leaning towards the RX-8 so I can have two Mazda's, but I've always liked the IS. We will see...
Nick
Reversibly LS swap your RX7
The other issu I've read is availability of parts. Pontiac is out of business and the car is Autralian, so anything outside the drivetrain is a pain in the neck to find.
The SS has the same problem the G8 does: weight. And, they both are pretty expensive. I'm trying to get everything done, car and all for less than $10k. It will be a challenge, but if the body costs me less than $3k, it's doable. It just depends on the deals I can find on the drivetrain and which drivetrain I actually settle on.
Nick
I agree with the RX8 swap though. I plan to attempt on in the winter or spring.
The end-goal would be 300+ whp, depending on which engine I settle on, this should be a relatively easy goal. However, I'd like to maintain a fuel efficiency of at least 25 mpg, with a stretch goal of 30 mpg on the highway. With the right gearing, 30 mpg may be possible. The final drive for the RX-8 will definitely need to be changed though, and from what I've read, I'll be limited here. They come with a 4.44 but the RX-7 automatic final drive was 3.90 and they're interchangeable. I'd like to go even lower, but I am not sure what the availability would be for that.
Now, if I swapped to a Ford 8" rear end, now I've got tons of options. So, initially if I don't achieve my efficiency marks I'm hoping for, then I have an option down the road. Having said that, the fuel savings it would equate to would not pay for the swap in all liklihood so a 3.90 may suit me just fine!
Nick
I absolutely want an automatic though. It's a daily driver, so I want convenience and comfort. I've got my FD for the weekends and will happily run it through the gears. But here in Miami, stop and go traffic is terrible. Auto or no swap my man.
Nick
