LS1 & Internet Acronyms - Defined
Old Apr 7, 2006 | 02:42 AM
  #41
LS1Lust's Avatar
How about OEM, I am still not 100% on that one I think it has something to do with original... and thats where I loose it.
~Alex
Old Apr 7, 2006 | 03:37 AM
  #42
wdtiger's Avatar
Original Equipment Manufacturer.
Old Apr 7, 2006 | 01:23 PM
  #43
leftme4dead's Avatar
I keep seeing SI. What does this stand for?
Old Apr 15, 2006 | 05:32 PM
  #44
murphy54's Avatar
good job with this it was really needed(by me)
Old Apr 16, 2006 | 05:16 PM
  #45
ACW's Avatar
ACW
What's the context?
Could be the metric system of measurement (Système International).
Old Apr 18, 2006 | 10:56 PM
  #46
Wesmanw02's Avatar
Originally Posted by dajodsterman
What does DA stand for? Does it have anything to do with elevation?
District Attorney??
lol I dunno...
STS ?? .. I see it AT threads discussing TC's ... (I like accronyms!! .. I can't spell worth a crap! .. and I type even worse))
STS can also stand for ShorTy-Shifter
Old Apr 23, 2006 | 12:41 AM
  #47
jlrz28's Avatar
10 Second Fun Car
Possibly add SCR and DCR?
Old Apr 25, 2006 | 03:57 PM
  #48
Mauser8's Avatar
This list is quite neat. Thanks :-}
Old Apr 25, 2006 | 04:14 PM
  #49
Tudds's Avatar
DA- Density Altittude
I never understood what NOS.
NOS- New old stock
They are still making stuff for our cars so I guess this term hasn't made its effect here
Old Apr 26, 2006 | 12:44 PM
  #50
SHINER's Avatar
whats LDA stand for?
Old Apr 26, 2006 | 11:33 PM
  #51
ACW's Avatar
ACW
Lobe Displacement Angle, talking about camshafts. Also called Lobe Center Angle (LCA). And also called Lobe Separation Angle (LSA).
http://www.hotrod.com/techarticles/2945/index.html describes it as:
Definition: Lobe center is the amount of camshaft degrees between the point of maximum lift on the intake lobe and the point of maximum lift on the exhaust side of a given pair of cam lobes. As an example, lobe center is calculated for cylinder number one only and does not deviate between number one and the other cylinders in the powerplant. To make a representative sketch of lobe center, draw a line between the very center of a camshaft intake lobe and then draw a similar line through the respective exhaust lobe for the same cylinder. The number of camshaft degrees between these two imaginary lines is the camshaft lobe center.
Also called lobe displacement angle (LDA), the lobe center has a definite bearing on how a particular camshaft will operate in a specific powerplant. If the lobe center of the camshaft is increased, the valve overlap will be decreased. The overlap decrease is created because the exhaust timing will occur earlier and the intake timing event will occur later in relation to crankshaft position. Conversely, if the lobe center or displacement angle is decreased, overlap increases. Note that lobe center cannot be changed once a camshaft has been ground.
Old Apr 27, 2006 | 07:54 AM
  #52
SHINER's Avatar
i know what LSA meant..didnt know there was a LDA, thanks for getting that info for me!
Old Apr 30, 2006 | 07:01 AM
  #53
msgZ28's Avatar
Devil Dog, OohRah!
DSM stands for diamond star motors right? What all vehicles fall under that category or whatnot? I have always wondered this. I know talons and eclipses, but those are the only ones I'm sure of.
Old Apr 30, 2006 | 08:10 AM
  #54
Nine Ball's Avatar
LS1Tech Co-Founder
Correct, DSM is Diamond Star Motors. Basically all Mitsubishi vehicles, and the Eagle Talon since it was built by Mitsu. Some people also include the Dodge Stealth, since it was built by Mitsu (sister of the 3000GT).
Old Apr 30, 2006 | 08:19 AM
  #55
unit213's Avatar
Administrator
Hard to tell without knowing the context. I beleive it would be Stock Internals
if someone is referring to their mods.
NOS- New old stock
I'm confused by this. "New old stock?" What the hell is that? The only
NOS I know of is Nitrous Oxide Systems.
Old Apr 30, 2006 | 12:26 PM
  #56
SHINER's Avatar
NOS is basically the same thing as same OEM, you usually see that word when by restoration parts for classic cars...
Old Apr 30, 2006 | 09:36 PM
  #57
ACW's Avatar
ACW
Yeah, 'New Old Stock' is old/discontinued/obsolete parts that aren't manufactured anymore, but a bunch of them were 'saved' before manufacturing stopped -- sitting unused/unopened on a dusty shelf for decades.
Old May 8, 2006 | 10:14 PM
  #58
lechner80's Avatar
Question Evap
What is EVAP. Anyone Have a picture? Is this something that can be removed? Thanks
Old May 8, 2006 | 11:29 PM
  #59
ACW's Avatar
ACW
It's an abbreviation for the Evaporative Emissions control system.
http://www.carcare.org/Emission_Cont...p_system.shtml
http://www.canadiandriver.com/articles/jk/050622.htm
http://web.bsu.edu/tti/5_1/5_1e/5_1e.htm
http://www.familycar.com/Classroom/emission.htm
Old May 9, 2006 | 07:06 AM
  #60
lechner80's Avatar
Thumbs up
Talk abount information overload Thanks.
