LS1 in a 1967 camaro swap help.
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Whats going on everyone, a buddy of mine was telling me about this cite and i have read some verry verry good information. I am going to be atempting an LS1 swap in a 67 camaro. I am thinking about going with one of those magic stick 4 cams and some kind of heads, i am not sure on the ones to use. My original plans for the car was to put a big block and try and make 700 horses. Now i am for sure going to go with the LS1/t-56 speed combo. Does anyone have any tips or know of any tricks i will need to know. I am also going to go with one of those TCI front subframes unless i could bet buy with doing something to my original one and get the same performance out of it. Thank you and i hope to get some info from the people who know about these motors and engine swaps.
Welcome to the board. LS1`s fit quite nicely in a first gen camaro. There is a lot of info out there and on this board to help you along. You need to check out the conversions and hybrid section. Also, there is a company called ATS that specializes in LS1 conversions into first gens. There is another called Detroit Speed that has some great products as well. Your stock frame, unless damaged, is plenty frame for your car. Do not go with the TCI frame. It`s a drag only frame. Your welcome to pm me any time with questions on your conversion. I have a 67 and a 69 camaro as well. The 69 is getting a LS1.
Awesome guys, thanx for the heads up. I hope to get some pictures up as the build comes along. So the TCI isnt a good way to go? I talked to them direct yesterday and you could buy pretty much a whole frame (front and back subframe along with the subframe connectors) minus the rear dif. but i have 12 bolt posi with 4:10 gears i am going to use. If i went that route i could build a whole rolling chassis and set the motor and trans in do all the plumbing while my car is in the body shop. But if i could get by and use my original frame and still be able to get the same kind of handeling for cheaper then i would definatly go that route so then i could put more money in the motor.
P.S. If anyone knows of anyone who would be interested in buying a bad a$$ 1964 el camino that is pretty much done with an awesome paint job (around 11K in just the paint and body work) it has a small block with a M-21 4speed. I also have a 1970 Monte Carlo it is suposed to be a SS car but i am not sure. I have pictures if anyone would like to check eather one out.
LS1Tech Co-Founder
Welcome to the site Jon,
Several of us on this site have transplanted LSX engines into 67-69 Camaros. You will find tons of info in this forum:
https://ls1tech.com/forums/conversions-swaps-28/
You can also use the search feature to find valuable info for the swap, if the search button isn't acting up (haha). The Search button is located at the top of the screen, on the pull-down menu bar.
Tony
Tony
