who's interested in a custom NX style switch panel
Old May 30, 2003 | 10:11 PM
slow's Avatar
Default who's interested in a custom NX style switch panel
I found the company that makes switches exactly like the NX switch panel.
As most of you know, the NX panel works great, for NX products, but different aftermarket accesories use different wiring configurations, which are not always compatible with the
SPDT, SPST (mom) and DPDT (mom, mom) switches that come in the NX panel.
(mom) = momentary
I am gauging interest in custom assembled panels, just like the NX one, but your choice of switches, (and more affordable too)
Switch styles available.
SPST
SPST (mom)
SPDT
SPDT (mom, mom)
DPST
DPST (mom)
DPDT
DPDT (mom) .....(used for NX openers, or Electric cutouts)
SPTT (triple throw)
and then lighted versions available too
SPST (light)
SPDT (2 lights)
DPST (light)
DPDT (2 lights)
switch colors are as follows.
black. (no light)
black w/ red lense for light
black w/ amber lense for light
black w/ green lense for light
black w/ 2 red for light
Also available in red switches,
red (no light)
red w/ red light
red w/ amber light
red w/ 2 red lights.
Pricing is not yet setup, just gauging interest in these panels.
Thanks.
Ryan
Old May 31, 2003 | 05:56 AM
CAT3's Avatar
Restricted User
Default Re: who's interested in a custom NX style switch panel
How many switche scan be installed in the panel?
1x Arming
1x Heater
1x Purge
1x Remote Opener
1x Fan Hi/Lo/Off
What else??? But that would be worth it!
Old May 31, 2003 | 12:45 PM
slow's Avatar
the NX is a 3 position panel. These are the exact same switches, with a lot more options on how they are wired. (i.e. you can have your arm and heater on one switch, like NX uses) or have seperate switches for all.
Stock 3 fit as good as the NX panel does.
However, they are modular units, and if you dont mind cutting your panel, im sure 5 could fit across. I dont think you could do only 4, as the cigarette lighter hole will get in the way.
They do have "Blank filler" plates, for unwanted switch positions, so if you dont mind losing your cigarette lighter, you could do 5 across, and use one filler.
Ryan
Old May 31, 2003 | 04:02 PM
66ImpalaLT1's Avatar
These switches can be bought from http://www.waytekwire.com
Look for Switches, Contura rocker. Here's the catalog pages for them:
http://order.waytekwire.com/IMAGES/catalog/215_36
http://order.waytekwire.com/IMAGES/catalog/215_37
Do you think you can get enough interest to buy in bulk for the discount?
Eric
Old May 31, 2003 | 04:04 PM
[JFS]'s Avatar
Old Jun 1, 2003 | 02:55 AM
slow's Avatar
that is what i am trying to find out, if there is interest.
They sell some of the switches i have available, but not all, There are TCS switch covers available in the same line, so the Bird guys w/ TCS, you can add a 2 position panel, and keep a TCS switch. also, waytech, has a $5/ item minimum order, so to build a NX clone panel, will cost an individual around $50 with shipping.
I will also be designing plug and play wiring harnesses for N20 setups to go along with the switch panels.
Ryan.
