C5R Block VS Standard LS1
i cant believe i am hearing this..
i always thought MMS was a halfway decent company. i know there is no sponsor bashing allowed, but i can say that after this and a few other things i have heard.. i will never spend a dime with them.
MY thoughts EXACTLY! that's a bunch of $hit. all that cash and they can't do anything.
![MAD](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_mad.gif)
let more performance handle it...they are the shiz nits. they do awseome work. i'm over at there shop at least once a week buying **** for friends cars and mine. they've never once yelled at me for bugging the bejesus out of them...and i know i do.
I'll never buy a damn thing from them. You don't ask people to step up, you expect it.
This is more like things I've heard about them than not...I coulnd't afford to look the other way.
I got some shots of the car today. Here's two cracks and two recesses in the sleeve.
![](http://www.iateyourcat.net/ss/sleeve2ls1.jpg)
![](http://www.iateyourcat.net/ss/sleeve1ls1.jpg)
![](http://www.iateyourcat.net/ss/crack2ls1.jpg)
That tiny black spot between the sleeves is a crack.
Larger pictures here http://www.iateyourcat.net/ss/crack1.html
According to Mike Moore the sleeves are just too big for the block. The width of the block between the sleeves isn't enough to compensate for heat. Maybe that's why People are using the Darton Sleeves now or a C5R block. That doesn't explain the recesses in the sleeves though... Anyway, it should be rebuilt and in in about a week and a half and I'm going to pull the MMS229 cam and put an MTI S1 in while it's apart.
![](http://www.iateyourcat.net/ss/crack1ls1.jpg)
Wish I had the $$$ to drop on a 6,000 block
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Those sleeves have dropped. Not just anyone can sleeve motors. I had no idea MMS did!!!! ANyhow that is a terrrible job no matter how you look at it!
Also to answer the original question. The C5R must be modified for wet sump operation. Originally it is a dry sump block. Lingenfelter has there own version of it with wet sump operation....and we all know their product is proven. Plus it comes with a 2 year warranty
...does this prove that re-sleeving blocks is near impossible? ...i heard the Darton sleeve system is about the only proven method, however...
....You should expect MMS to make good on their defective work...I would seek legal relief if they refuse..
Did you consider going with an LQ4 iron block instead of the exoitic re-sleeved aluminum block or the increadably expensive C5R block?
#32
I'll get in touch with Mike directly once the engine is fixed. I think we can work out something fair.
I think all of the new big bore blocks are using the Darton Sleeves. Here's a pic:
![](https://www.cartek.net/images/dartonnew.jpg)
They're modular and really look like a nice design. They appear to eliminate the thin wall problem and look like the best way to use a stock aluminum block. In fact, based on that picture and where my cracks are in the block, I could still have my block bored to use the Darton sleeves. It's a little late now for me to do that but maybe the blocks not scrap metal.
I thought about the iron block but I want the car to handle like stock on the street as well as launch well at the track. I've heard the iron block kind of screws that up.
#33
...the iron blocks are about 75lbs more in wieght than the alumimum blocks ...but you can buy them for a mere $700 plus shipping...
...How much is a Darton block including the core?
...A C5R is out of the question for me...
...i'm hoping i can do a LQ4 iron stroker for $4K and change....just now investigating it, however...
Good luck...
Good luck...
#36
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#37
7 Second Club
Location: Grove City Ohio/Port Washington L.I sometimes
Wise choice passing on the boat anchor iron block.Hopefully MMS will do something for you.I would have bought the C5R,but went with ARE's resleeved big-bore block instead.Keep us posted on your combo,and MMS response to your complaint.Good luck.
#38
I have
Al says "there's no warranty on nitrous engines." It doesn't matter that I haven't run nitrous. It's not even installed yet.
good luck with whatever you do
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#39
dude....thats BULL SH*T!!!!!
That pisses me off when companies won't warranty their products!!!!!
What baffles me is that none of you folks relaized that NOT ONE company out there will warranty a Block/Engline that's GOING TO BE USED with a POWER ADDER. MMS has no idea is anyone is telling the truth, etc. Heck, even MTI doesn't warranty the Engines that are used in combination with a Power Adder. When you are buying Aftermarket Racing Products, not everything is necessarily warrantied/guaranteed. Buy Beware when making such decisions.
MIr Naziruddin
#40
MIr Naziruddin
