My ambitious project
Old 10-20-2008 | 08:21 PM
  #121
Formula350's Avatar
Originally Posted by neilownz
yep that would be correct... a 1500 or 2500 chevy/gmc with a 5.3 or a 6.0 would be nice to mod.
heres a colorado "ss"
http://cgi.ebay.com/ebaymotors/Chevr...mZ120319502392
There are factory 5.3l Colorados though, I was just knocking the "Full size" bit. Since they're essentially an S-series.
That SS is sweet though, he did a good job on it. Wonder if the SS bumper off a Trailblazer would've worked? Drop the same motor and AWD setup off it under a Colorado... Typhoon anyone? (Or was the pickup the Cyclone? meh...)
Old 10-21-2008 | 04:56 AM
  #122
06 SS's Avatar
Cyclone
Old 10-21-2008 | 08:40 AM
  #123
BADDLS1SS's Avatar
well why wouldnt you just get a Z85 4x4 coly with the 5.3 and get the AWD when you want it? The Z85's look like 2wd's anyway.
This Cyclone? Good luck getting a S truck platform under this unibody ferd lololololol
OR
This Syclone?
Old 10-22-2008 | 03:43 PM
  #124
Red03GT's Avatar
So from what I understand, the issue holding back an intake swap is the oil plug for the DOD which sticks up near the TB side of the intake. Now, the LH8 that is in the 5.3L Colorado has the same motor that was used in the 5.3L Trailblazer/Rainier/Envoy minus the DOD crap. So the LH8 has a different valley cover as it doesn't have all the DOD crap. Theoretically, is it possible to remove some of the DOD items, plug up whatever oil lines, use the LH8 valley cover and be able to use any other LSx intake? Did that make sense? lol.
Old 10-22-2008 | 06:13 PM
  #125
06MonteSS's Avatar
LS1Tech Sponsor
don't think it'd be that easy...
here's the DOD info... https://ls1tech.com/forums/showpost....27&postcount=3
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old 10-22-2008 | 06:15 PM
  #126
BADDLS1SS's Avatar
That OIL PSI sensor will be there regardless on any gen IV so no there is no viable intake option yet w/o serious modifcation. I dont think the oil manifold is much of an issue from the DOD either.
Old 10-22-2008 | 08:05 PM
  #127
Formula350's Avatar
Yes, the latter Syclone I knew it was spelled wrong, and thought I was when typing it, but I didn't -_-
Old 10-23-2008 | 11:42 AM
  #128
mixerda's Avatar
alright ya'll got the dyno run in ect
after 6 pulls she put down 278whp and 263tq, was pretty heat soaked at this point so true hp numbers weren't showing. IAT where at 178, ECT where in the high 220's-low 230's so he estimates actually HP numbers to be about 10-15 more than what the dyno showed due to heat soak. The guy also didn't get the shift point set right in my mind, I wanted 1-2@6750 2-3@6500 3-D@5500 but car kept shifting at 6100, I think he just forgot to set the transmission shift parameters. Every time it shifted out at 6100 that was peak HP point. I think the cam will be good to 6300-6400 if not more before the HP curve begins to fall off some so I will mess with it later on.
if you just want dyno part of the vid skip to 6:17, other than that this is just a vid of everything put together from start to finish on this project.
http://www.youtube.com/watch?v=j2VJR8me-jw
Old 10-23-2008 | 01:11 PM
  #129
BADDLS1SS's Avatar
Ok but how does it feel on the street now? softer downlow with more punch above 5k?
Old 10-23-2008 | 03:36 PM
  #130
mixerda's Avatar
hope this answers your question some heh
http://www.youtube.com/watch?v=Iyrty-MriGM
Old 10-23-2008 | 04:49 PM
  #131
Garou24's Avatar
So what cam did you end up putting in? Looks like some good pickup and nice Dyno numbers.
Old 10-23-2008 | 05:03 PM
  #132
20SS07's Avatar
From his one video.....Thunder Racing 224/224 112LSA cam
Old 10-23-2008 | 05:18 PM
  #133
BADDLS1SS's Avatar
Ill have to get a vid up of mine. I think mine might be quicker 60-80. Ill post tonight.
Old 10-23-2008 | 05:28 PM
  #134
07carlocrusader's Avatar
this thing sounds badass!!
Old 10-23-2008 | 06:14 PM
  #135
BADDLS1SS's Avatar
fresh off the cam:
http://www.youtube.com/watch?v=hPxjJP311Ao
http://www.youtube.com/watch?v=EBwYYboWkfs
Very little in the way of mods anymore, stock valvetrain aside from 918 springs. Catless DP, my HPT tune and modified stock airbox and filter.
Old 10-23-2008 | 06:29 PM
  #136
mixerda's Avatar
I'll try and get some higher speed runs later tonight kidna busy atm and gotta run over to a friends house, no good roads to do these kinda speeds at going there I'll try to also get my launch a little better I keep loosing grip anything less than 30-40 and sometimes even then depending on patch of road I'm on.
edit did you ever get your dod noise issue figured out or just turn it back off?
Old 10-23-2008 | 06:35 PM
  #137
BADDLS1SS's Avatar
It was more of an engagment surging issue than noise. With the stock cam and valvetrain back in its nice and quiet. Right now the DOD is off. Little more pleasureable to drive that way.
Old 01-18-2009 | 11:15 PM
  #138
G8-4-speed's Avatar
This is an 01' LS6 cam, so it has only .525" lift. that comes to .556" at the valve with a 1.8 rocker.
The DOD lifters only cares about the lift at the cam. Because when the lifter "free wheels" for lack of better words, its gonna depend on how much free travel the lifter has to whether it can accomodate the added lift. So if the lifters can take the added .046" in lift internally the system should operate the same.
I want to correct the pushrod length issue first before i kick the DOD back on.
Amazing how much of a bump in instant fuel econ at a cruising speed in V8 mode between the 2 cams, i cant wait to see what it does with the DOD working.
What is the total lifter travel for a DOD set at zero lash?
Old 09-23-2009 | 05:07 PM
  #139
Sittingmongoose's Avatar
I think my car is acually faster than both of them. It hard to tell. You guys think its worth doing a ls6 cam? I have the engine apart completly.
Old 01-29-2011 | 09:26 AM
  #140
91_rs-teal's Avatar
it would b awesome if you did a ls6 intake swap and showed numbers i bet you get 290 to the wheels
Quick Reply: My ambitious project
