Question concerning Our K&N Intakes!!
Old Oct 29, 2008 | 04:34 AM
07carlocrusader's Avatar
Default Question concerning Our K&N Intakes!!
Well I have a K&N Intake & as I perform my normal inspections of the crusader, I notice a gap between the bumper and headlight! Its a sufficient amount of gap. I never hit anything! Headlight is in correctly. Bad thing is, the left headlight has no such gap! Once I lifted the bumper, it doesn't seem to have a lot of play in it, & appears/feels to be pretty stable. So I don't know if this is how it should be or not! You LS4(Imps & Monte) guys need to go out & check that right(and left) headlight along the bottom to see if gap is present!! And would this be a concern for our intakes when it comes to heavy rain or even washing the vehicles please let the crusader know thanks,....
Here are a couple of pics:
You can see visible gap along the bottom of this right lamp
here I ran a small phillips along the bottom of this lamp with EASE!! Am I just paranoid??
Old Oct 29, 2008 | 08:15 AM
bigboy3l's Avatar
I have a small gap between the hood and the light on the drivers side. Very hard to notice. I tested if water would get through there when I installed the K&N I sprayed the **** out of it with a hose. No water. However I did get my K&N wet once in a heavy rain.
See this thread for details: https://ls1tech.com/forums/showthrea...336&highlight=
Old Oct 29, 2008 | 12:29 PM
neilownz's Avatar
get the drycharger for $35 if you want to make sure water wont get in.
Old Oct 29, 2008 | 12:38 PM
Formula350's Avatar
Pull the K&N setup off and see if it goes back to being flush If so, it's the cause, if not then it's just coincidence you noticed it after the fact.
Old Oct 29, 2008 | 03:10 PM
look here!! the gap is pretty visible on Mike's car in the very 1st pic!
https://ls1tech.com/forums/ls4-performance/1008318-ssc-s-monte.html
Old Oct 29, 2008 | 03:46 PM
2006ImpalaSS's Avatar
I don't see anything like with my CAI.
Old Oct 29, 2008 | 08:10 PM
bdyman's Avatar
how could the intake cause a gap between haedlight and bumper??, the ones i have worked on all had the gap, or are you saying becasue of the gap the intake might take in water right??
Old Oct 29, 2008 | 08:51 PM
well the intake itself doesn't cause the gap! I'm assuming that the gap was already there. & this is what makes great concern for my intake sucking in water!
Although I did make a different intake trim on my K&N due to the fact of how lousy the K&N trim peels off!! I ordered free trim for the 2nd time & covered it with some piping foam wrap so it is a lot thicker. The Hood was just a "little" more difficult to shut but not much at all! This should have not cause so much Gap under my headlight simply because when I'm pushing up on the bumper it barely moves!! Now had it been a lot of play in the bumper, that would be a different story! Check out revised K&N trim!
I took a little off the top & the hood shuts back to normal but the gap is still there. Its almost as if this car was just manufacture like this. I've seen a couple of Imps & montes where one Lamp had gap & the other did not, uneven bumpers and etc! I sprayed water straight thru the right side where the gap lies & I did have a couple of drops & small puddles by the PCM. So I probaly will line some seal along the bottom of the lamp itself, & call it a day!
Old Oct 29, 2008 | 11:25 PM
MonteSS8707's Avatar
I had that gap but only when I installed my aftermarket headlights. I used too washers to shim the new headlight where it bolts to the fender. It solved this problem. Re-aim your headlight beam too.
