LED Tails are installed
Old Nov 28, 2008 | 11:08 AM
steveman0018's Avatar
Default LED Tails are installed (NIGHT PICS JUST ADDED)
Ok I installed the Eagle eyes LED Tail lights 2 weeks ago and they look great.. The problem with them is the resistor that ships with them is not powerful enough. The turn signals blink very fast which could be ok for some, but i dont like seeing the green turn signal light blinking on my dash so much.. So i had to go the other route. Get an electronic flasher or get a load equalizer. Well there no electronic flasher for this car so i had to buy the load equalizer.. I got them from v-led for 8 bucks.. I installed them the other night and bam, the signals are now blinking like normal again..
I love the lights, they are very bright and u can see the road light up red behind you in when its dark. There is also these three LED lights on the side of the tail lights that help shine on the sides of your car..
Here are some pics of my install. there really only two since its not complicated. I took these pics from my blackberry storm, so the dark one might not seem very clear...
This is what they look like during the day
in this pic below, this shows where you need to tap into your cars tail light harness. If you take off the plastic covering in your truck right by the latch, you will see wires taped with electrical tape coming out of a gromment hole.. Carefully cut about 5 inch of electrical tape off so you can see the wires and have enough play..The two turn signal wires are the yellow wire and the dark green wire. You will attach one resistor to the yellow and the other one to the dark green using the supplied splices. The other end of the resistors connect to the black wire. That big buldge of electrical tape is where the splices were done..
Lastly, you need to mount the resisitors as they get very very hot. DO NOT mount them behind the tail light, on the tail light, or near anything plastic or near the carpet. You dont want a fire or a melted tail light plus i dont know if they are waterproof.. What i did was i mounted then inside an opening in the trunk frame. If you look at the pic above, u can see the opening.. I mounted them with metal screws and dressed the wires so they dont touch the resistor.. Job complete.. make sure you put electrical tape back on the splices and your done..
once it gets dark, i will post a pic of what they look like at night.. Any questions, ask
Old Nov 28, 2008 | 11:25 AM
mike690003's Avatar
Those look really nice. Like an updated OEM look, not ricey at all.
Old Nov 28, 2008 | 12:12 PM
yea they are nice and the keep the factory look except seeing all the leds inside.. i am not a fan of the ones that are chrome plated. i like the cool factory red look.. At night there amazing.. just waiting for it to get dark and i get a pic.. by the way if you got verizon, get the blackberry storm.. the phone amazing and these are my first pics with it and it takes pretty good pics, even in darkness..
Old Nov 28, 2008 | 05:37 PM
ok here are the pics at night.. sorry if they seem blury but they are too bright for the camera..
and this is from the side to show you the 3 led on the side of the tail light.. overall if you want a new sexy look to the car, get these..
Old Nov 28, 2008 | 05:42 PM
mike690003's Avatar
Too bad there are none that nice looking for the Monte
The Monte ones are rice central!
Old Nov 28, 2008 | 05:47 PM
yea i havent seen the monte ones. im sure they will come out with them... these led tails are made by the same ppl who did the projector headlights.
Old Nov 29, 2008 | 06:22 PM
4doorSS's Avatar
sweet look man i want i want how much?
Old Nov 29, 2008 | 10:35 PM
there not cheap man.. 195 on ebay, you might find them cheaper on another ebay store but that the best i could find..
oh by the way, the backup bulb i bought seperate. it finny that these are led tails but still use your stock back up bulb.. i bought led bulbs for the backup..
Old Nov 30, 2008 | 12:14 AM
The Guz's Avatar
The LED tails look great.
Old Nov 30, 2008 | 10:40 AM
lovemyls4's Avatar
whats the part number on the backups??? where did you get em ?
Old Nov 30, 2008 | 11:44 AM
our back up bulbs sizes are 921.. you can get them from any LED seller, but i got mine from v-led. almost my entire car has LED nows replacing the stock bulbs and i have bought them all from v-led.. good prices also.. the ones i bought are not very bright though b/c there not true backup lights.. i didnt want to spend too much for bulbs.. they have back up leds that start at 20 bucks and they got led surrounding the bulb instead of being in front of it..
www.v-leds.com
Old Nov 30, 2008 | 12:18 PM
4doorSS's Avatar
sweet i found some i ordered them and the bulbs and the load stabilizer i will install them along with my headlights and HIDs
Old Nov 30, 2008 | 01:40 PM
cool man, u will like them.. if you need any help let me know.. remeber that the turn signal wire are the yellow wire and the dark green wire
Old Nov 30, 2008 | 02:02 PM
Nacho SS's Avatar
They look great...hopefully someone can come out with nice LEDs like that for the monte, not that riceboi stuff that is on eBay.
Old Nov 30, 2008 | 02:51 PM
SSWS6's Avatar
Hey those look nice! I have been thinking about getting these ever since I saw them on Ebay.
